Cinema4D version 2023.1.2-[R7] (Obsolete stable) 27.03.2024
miohn wrote:sorry solved!
Was a problem with C4D Matrix Object, that the softbodys were jumping back
to its original form every frame. Was only recognizable when stepping from frame to frame.
need your help please, because I've no idear whats going on.
I have a cached softbody simulation which runs fine in the main viewport.
But when I render it to PV all stays rigid . No softbodys get rendered correctly.
Did it like I always did.
Latest C4D and latest Octane.
What I doimg wrong here?
thanks
Mike
Can you understand what you say here? I cannot!
miohn
please delete this post because it was not Octane related!
Just to explain:
I was close to the madness because the animation with cached softbodys
looked fine and correct when playing the animation in the main viewport in Quickshading mode.
But when I rendered the animation to the PV, the softbodys did'nt move like they should.
They stayed rigid.
But when I stepped trough the animation in the main viewport (with shortcut "g") frame to frame,
I saw, that the deformed softbodys jumped back to their original form after each step. (was a priority problem)
o.k.?
regards
Mike
SSmolak
aoktar wrote:
SSmolak wrote:Weight map freeze Octane but Attribute node works fine.
What are you talking about?
Weight ( baked ) node cause hard freeze but Attribute node with the same weight works fine :
Delizade
After I installed R6, all materials were black in the LV. In the node editor texture previews were black but when I clicked to texture nodes I could see texture previews.
I installed 2023.1.2 [R5] version and materials came back.
I don't know, maybe it's caused by my system, but if I should do something related to the latest version, could anyone share, please?
Thank you
Delizade wrote:Hi,
Thank you
Removed R6 temporarily, I'll check it. Stay with R5 during this period. Thanks for reporting!
Fixed Windows builds are back. Please download and try again!
Delizade
aoktar wrote:
Delizade wrote:Hi,
Thank you
All materials are fine now. Thank you!
miohn
I didn't dare to report this error with black textures :cry:
miohn wrote:I didn't dare to report this error with black textures :cry:
Re-download it, replaced with fixed build
freeter_e
feedback:
Cinema 4D 2024.2.0
Octane 2023.1.2-[R6]
viewport solo, in some scenarios, not work fine
Octane 2023.1-[R7]
test, it's ok
augdalmo
Hi Aoktar,
Solo mode does not works on C4D R23, I have tried all plugins releases for Octane 2023.1.2
it works only on Octane 2023.1
Return to “Releases”
