Shape field working?
Bulwerk
It's been a while since I've seen a post about the shape field node and wanted to see if anyone was having luck with it?
Currently trying to make an SDF with an Octane Object tag set to Mesh to SDF. I then use that SDF as the input for the shape field.
Shape field.zip
(205.86 KiB) Downloaded 129 times
SSmolak
It works
But remember - you must be very quickly. You have only 10 to 45 seconds for playing with it. After that Octane will freeze. Anyway in Octane 2024 alpha.
Shape field2.zip
(137.99 KiB) Downloaded 107 times
Bulwerk
Thanks for the reply SSmolak. I was using 2023.1.2 and had no luck.
Obviously it would really amazing if this feature worked more consistently.
