OctaneRender® 2024.1 Alpha 2
john_otoy
SSmolak wrote:Can you check how Mesh to SDF with Field Shape texture works on this alpha ? I don't know how to setup nodes in Standalone but in C4D version it works extremely slow compared to previous versions...
One of your previous C4D samples files had imager > minimum display samples set to 12 instead of 1.
This is going to make everything feel much slower. Can you check you're not doing this in your latest scene?
SSmolak
john_otoy wrote:One of your previous C4D samples files had imager > minimum display samples set to 12 instead of 1.
Yes that help a lot with speed if camera is at distance from simple SDF cube but it is terrible unstable - freeze after seconds. This is why I ask about it because it works fast and stable in the past.
Kalua
Hi, Team
Could u please bring support to Nvlink (2x3090)?
Engine won't start when peers are identified.
Regards,
octane 2024.1 Alpha 2 240113 094401.txt
(1.13 KiB) Downloaded 210 times
Octane User since V1 Beta
john_otoy
OctaneRender 2024.1 Alpha 3 has been released: viewtopic.php?f=33&t=83054
