Instancing trouble v2023
Builtdown
Hello,
This is not Octane related but I throw it here anyway:
I have now Lightwave2023.
My work requires lots of use of instancer. Now with v2023 it seems to be broken or then I don´t know something about it.
This is how I used it before (v11):
I had an object (like a yard of a house) and an object like a bush. For yard I put on Instance Generator. In that I add the bush-object. Set it to Local, put in on Surface and then I was able to set Scale, Rotation, etc.
Now with v2023 when I do the same, the Instance Generator doesn´t work. The bushes are set in really weirdly manner, especially if I close and REOPEN Instance Generator. And move the object in between.
Does this happen to others also?
If you can test this, please try to also move the objects while testing Instancer. It also affects the instancer.
This is horrible because I will lose my customers if I cannot do the jobs because of this!!
Builtdown
It seems to have everything to do with moving the object. Anyone gets the same result?
Builtdown
Other example
pixym
Hi Builtdown,
Very strange behaviour.
I suggest you to post this on the #quick-help discord : https://discord.com/channels/1091002236 ... 1553831042
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
pixym
For the armchair, have you checked the update instances button in the main Octane panel ?
promity
Post your scene.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
Builtdown
Thanks for the replies.
...This is Lightwave problem. Nothing to do with Octane.
I attached model and a scene:
Frame 0 works well when you go to Instance Editor to change something.
Frame 1 with moved object you go to Instance Editor and change something. Then comes the trouble (at least for me)
RAR_download.rar
(9.03 KiB) Downloaded 521 times
promity
Everything right for me.
Lightwave 3d
Builtdown
Thanks, Promity, for trying.
You used v2023?
Did you try to change instance parameters on frame 1?
For me frame 0 and 1 works well if not change instance parameters, but problems come when open Instance Generator. (See attach.)
promity
Yes, indeed, I got the same result as you - but if I click on the DISTRIBUTION menu and select the RANDOM method - everything returns to normal. LW2023.
Lightwave 3d
Return to “Lightwave 3D”
