Cryptomatte Halo around Objet ID at compositing in AfterFX
Joanlaninja
I have rendered cryptomattes with Octane, and when I import the Octane EXRs, I can separate the mats from different layers, but they have a halo around them, and are not perfect. After finishing composition I have a little gap around every object....
Could it be an issue with checking the premultiply box? Are there any specific settings that need to be used? It's crucial that the mattes are accurate; currently, when composing the scene, there are gaps when separating different objects, and I'm using a resolution higher than 3000 pixels wide. I can't find a post that clearly presents a solution to this problem. I would greatly appreciate any kind of assistance, please.
frankmci
If you can share a simplified scene file (like just a couple of cubes or spheres) that exhibits the problem, it will be a lot easier to suggest fixes. To share it here, zip the file first so that the forum knows how to handle it properly.
Joanlaninja
I attach a pic to show whats my problem, yo can see how the cryptomatte dont cut the object properly, always u have this edge. I tried everything, multiplied alpha, raising crypto subds... I´m desperated with this...
I hope I´m missing something, if there is not a way to properly split layers via render passes I have a great problem.
Thank you for the help, appreciated and sorry for my english.
BK
Joanlaninja wrote:I attach a pic to show whats my problem, yo can see how the cryptomatte dont cut the object properly, always u have this edge. I tried everything, multiplied alpha, raising crypto subds... I´m desperated with this...
Hi Joanlaninja,
thank you for posting the rendered image.
Please try to uncheck/disable the **Disable partial alpha** from the Imager node and see if it works.
cheers
Kind Regards
bk3d
Joanlaninja
No it doesn´t work. I tried every single option with matte precompose and multiplication, it just looks like a bad behaviour of cryptomatte thing, not in this file but in every single file I´ve checked. This kind of things ruin a work and are really frustrating.
BK
Joanlaninja wrote:No it doesn´t work. I tried every single option with matte precompose and multiplication, it just looks like a bad behaviour of cryptomatte thing, not in this file but in every single file I´ve checked. This kind of things ruin a work and are really frustrating.
Could you please PM the orbx scene for us to investigate?
cheers
Kind Regards
bk3d
pegot
I’m often running into this issue as well. One thing that can sometimes help a bit is applying the ExtractoR filter and clicking the UnMult checkbox. It doesn’t always work but worth trying. And maybe look into your project’s color and linearization settings?
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
Return to “Plugin Discussion/Support”
