Network rendering sudden slowdowns
epicmind
We do network rendering, and I notice that from time to time, network render times become magnitudes longer (like from 30 seconds to 4+ minutes). If I close and restart Cinema4D, network rendering is back to normal. Anything that can be causing this? See attached for the version information. We often batch render after the work day, so if we leave and this happens, it can make is loose valuable rendering time.
weird, this is not common.
Please remove the installed c4doctane version and upgrade to 2022.1.2-R4:
https://render.otoy.com/customerdownloa ... R4_win.rar
Please use 7zip to uncompress the .RAR archive, it is free:
https://www.7-zip.org/
Then, it is possible to generate a log from the daemon, and run it in a more verbose mode.
Please, copy paste the attached `octane_daemon_log.txt` file in the Render-Node directory:
octane_daemon_log_flags.txt.zip
(911 Bytes) Downloaded 75 times
Then please perform a rendering session with Network rendering active, and the Render-Node connected until slowdown.
Then navigate to `C:\Users\UserName\AppData\Local|temp`, or write %TEMP% in the Explore path field.
Locate the octane_damon_log.txt file and share it, thanks.
It would be nice to have also the corresponding c4doctanelog.txt file from the Workstation.
So before starting to render in Network, please, open a scene that is giving you issues, then go to c4doctane Settings/Log Output tab, and enable all the Log option checkboxes.
Then, load the scene in Live View with Network rendering active, then in Picture Viewer until slowdown, then go to c4doctane Settings/Log Output tab, press the "Generate log report" button, and share the octanelog_report.zip file, thanks.
ciao,
Beppe
epicmind
Thanks - I will try this out and submit.
