OctaneRender® for 3ds max® v2023.1 - 14.05
- paride4331
Hi Rik,Rik wrote:Just out of interest Paride, what was wrong with the HDR environment and camera settings?
He used a cylindrical projection.
merid888
Hello Parid, wich will be the correct settings with Hdri ? Becouse if I don't use cilindral option in the scene appear two times the sun and affect the result of my scene, can you tell the correct setting ? and the option when i use Linea off I remember this setting with this option, not Srgb or I am wrong ? Please, correct me if I am wrong, thank you for you comment.
- paride4331
Hi meris888,merid888 wrote:Hello Parid, wich will be the correct settings with Hdri ? Becouse if I don't use cilindral option in the scene appear two times the sun and affect the result of my scene, can you tell the correct setting ? and the option when i use Linea off I remember this setting with this option, not Srgb or I am wrong ? Please, correct me if I am wrong, thank you for you comment.
However, the issue you're referring to doesn't stem from the projection but rather from the incorrect setting of the environment. Take a look here:
viewtopic.php?f=27&t=78198&p=403275&hil ... nt#p403275
- paride4331
Hi Templas,Templas wrote:Hi guys, thanks for fixing the bugs and for your work![]()
I wanted to know if there is a possibility to make the "Analytic light" light source invisible.
It will be resolved in the next release.
merid888
1) When trying to change Volume Ramp, the preview does not update.
2) Position 1.0 of "green arrow" in Volume Ramp moves arrow outside of gradient tab.
3) It would be great to be able to open the gradient ramp in a new window and scale it. It's really hard to pick out those big arrow triangles when they're standing quite close together.
Volume Medium material -> Schlick scattering direction: missing "sun direction" parameter.
- neonZorglub
Hi ramone163,ramone163 wrote:1) When trying to change Volume Ramp, the preview does not update.
Thank you for reporting those issues. This should be fixed in the next release. I'll try to also add a separate resizable window for better editing..
For the Sun direction of the Schlick, it should be available soon.
