Cinema4D version 2023.1-[R7] (Obsolete stable) 25.11.2023
SSmolak
aoktar wrote: 1-If you see the notes composite AOV and some others (with legacy text) reprecated. Don't create/use deprecated nodes anymore.
2-If you click again to button then you'll be out from Cryptomatte mode.
1. Understand now. Anyway it looks like composite AOV had better layers mixing options.
2. I thought that I need to click again on icon in LV window. It works as you described in node window.
Cryptomate Object node name doesn't work. All Layer IDs above 1 have the same colors.
SSmolak wrote: Cryptomate Object node name doesn't work. All Layer IDs above 1 have the same colors.
It works, put Octane tag and change the names
SSmolak
aoktar wrote: It works, put Octane tag and change the names
Ha yes I see now, but it gets Octane ObjectTag name not C4D Object name.
SSmolak
Beauty render AOV ignore all Camera Imager settings. Does it mean that all of the settings should be recreated by AOV nodes now ?
If we put value 0.1 in text field of Adjust brightness aov node it create 0.001 instead.
Scene with many objects needs to not only manually created unique names for Octane object tags but also unique layer id's. Not good for large scenes.
It would be great if copy-paste nodes copy also their node name :
jmachemer
Hello,
I have the latest stable version of Octane for C4D installed on my desktop, and I also installed the latest stable version of the Network Rendering Node on my laptop.
However when I go into the network rendering settings on my desktop, the node showed up, but I get an error saying that the render node version is wrong. Can we do network rendering with Octane 2023.1 R6 yet?
Any help would be much appreciated.
Thanks - Joel
Anim8me2
jmachemer wrote:Hello,
Thanks - Joel
Same issue here.
Any info available?
Network Rendering is working as expected in 2023.1-R6:
Please upgrade the Render Nodes to 2023.1 version:
https://render.otoy.com/customerdownloa ... de_win.exe
ciao,
Beppe
thanulee
Does "spread cutout hardness" work? It does nothing in 2024.1.0
Sunshine_wuyu
hair BUG
hair BUG
hair BUG
hair BUG
hair BUG
hair BUG
hair BUG
hair BUG
hair BUG
hair BUG
hair BUG.rar
hair BUG
(4.57 MiB) Downloaded 155 times
Anim8me2
bepeg4d wrote:Hi,
ciao,
Beppe
I downloaded and installed from the link.
Now the daemon just quits.
Return to “Releases”
