Hi everyone!
I was searching for how to use a specific hdri environment from a single material only while maintaining another hdri for the rest of the scene and I found this video on youtube from the user "Milan M"
https://www.youtube.com/watch?v=opRHoXP ... nel=MilanM
This is exactly the result I'm looking for but there's no clue on how to reach this result. Maybe the creator of the video is here and can share how he did it? That would be wonderful for me and I'm sure for many others as well. I searched on the forum but I can't find nothing related to this...
Per material Light/HDR in Octane LiveViewer
Just connect directly HDR image texture to specular input using spherical world texture projection. Set color space to non-color data or gamma=1.
You can easily disable HDRI environment from object tag using light linking "e".
In Redshift every material can have individual reflection environment, unfortunately in Octane you can only enable/disable one ENV but as I know there is no way to have two different. I tried to do something using RaySwitch node without success even using big sphere to simulate additional env.
Yeah, that's so sad. As you can see in the video I linked into the first post, it should be possible somehow...if only we could contact that "Milan M" guy....SSmolak wrote:In Redshift every material can have individual reflection environment, unfortunately in Octane you can only enable/disable one ENV but as I know there is no way to have two different. I tried to do something using RaySwitch node without success even using big sphere to simulate additional env.
OK it's done ! I forgot that emission can have it's own light link id
Two invisible spheres as HDRI envinronments with two different emmisive materials.
- custom_relf.zip
- (109.78 KiB) Downloaded 171 times
- two_hdri.zip
- (983.54 KiB) Downloaded 130 times
My friend that is AWESOME! I'll try it in depth more during the following days! If this have no flaws I definitely owe you a beer!SSmolak wrote:OK it's done ! I forgot that emission can have it's own light link idTwo invisible spheres as HDRI envinronments with two different emmisive materials.
We are living on big planet. I doubt our paths will cross. I'll have a beer with you, if not here, then in the afterlifepolloviz wrote: If this have no flaws I definitely owe you a beer!
You can use only one spherical object and one default Octane environment for your choice - their all will have its own light link id that you can choose from Octane object tag.
