OctaneRender for Maya 2023.1-22.8 [OBSOLETE]
Moderator: JimStar
Locked
JimStar
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2019, 2020, 2022, 2023 and 2024 64-bit on Windows, MacOS and Linux systems.
Octane for Maya masterclass:
https://www.youtube.com/watch?v=fANBzifhSow&list=PLTqdDmFtprFkzaBM7cmp8ZipQCNupDD0H
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone
Important: if using macOS, we strongly recommend that you update to version 13.3. Prior to 13.3, there is an OS related issue that causes a render failure consistently if you render for long periods of time.
Changes since version 22.7:
  • Improved the ORBX "alembic embedded" export functionality.
  • MacOS m1/m2 now can be loaded without Rosetta.
NOTE: Directional light in current 2023.1 Standalone is not affected by its parent transform rotation at all. This is why you can only rotate this light in Maya by a transform node connected to this light-node's "Transform" plug. At least for current Octane engine version...
NOTE: Don't forget to use the %p tag where you need the AOV-name to appear in the output path. I've found out that this has not been mentioned in the plugin manual, but it's going to be better described soon...
Subscription Studio+ Downloads
OctaneRender for Maya Studio+ [Windows]
OctaneRender for Maya Studio+ [Linux]
Prime Downloads
OctaneRender for Maya Prime [MacOS]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
g0ll4m
This just started happening randomly when installing. Any idea?
Windows 10
Maya 2024.2
2 RTX 4090s 192 gb ram
BK
g0ll4m wrote:This just started happening randomly when installing. Any idea?
Hi G0ll4m,
Thank you for the post.
Would you please let us know which Maya version was selected?
please try this latest build, same link as above. It has a nice fix that exports orbx with specified frames.
https://render.otoy.com/customerdownloa ... -_22.8.exe
cheers
Kind Regards
bk3d
g0ll4m
Hi G0ll4m,
cheers
It was 2023.1 Maya 22.7
Windows 10
Maya 2024.2
glimpse
hi there
quick question from Facebook group:
Does anyone know how to make octane update constantly in IPR, even on camera navigation movement? For me in Maya, it only updates when I let go of the mouse, but is there a way for it to update while I'm moving?
source: https://www.facebook.com/groups/OctaneR ... 491257680/
JimStar
Octane is only updated by Maya in IPR after all changes are finished. If you need constant update - please use Octane viewport renderer mode, it updates all the time but because of this uses much more resources both CPU and GPU.
g0ll4m
Hi G0ll4m,
cheers
I restarted my computer and 2023 installed fine, then if I have 2023 22.7 installed, and I then try to install 2021 1.4 20.16, it gives the same error.
Windows 10
Maya 2024.2
g0ll4m
Just tested again, I restarted and was only then able to re-install 2021 1.4 20.16. I'm unable to switch from 2021 to 2023 versions unless I restart my machine every time. Possibly during the extraction process? Can you guys test on your end?
Windows 10
Maya 2024.2
Locked
Return to “Releases”
