Shadow catcher broken on Octane X 2022.1.1 R6
azumbrunnen
I create a diffuse object using shadow catcher, upon activating shadow catcher it behaves like an invisible object instead of catching the shadows and letting light pass through. This messes up the lighting setup.
I also turned on Affect Alpha in the render settings but no luck. What changed?
jayroth2020
What lights are you using? The Shadow Catcher does not work with Environmental lights.
azumbrunnen
Oh that's the problem then. Is there any way to make it work or is support coming by any chance?
When I only use lights, they still penetrate through the shadow catcher instead of just rendering the shadow. So the light isn't blocked. Is that intentional?
jayroth2020
You can try using the Shadow AOV. If that doesn't work for you, file a support ticket: [email protected]
