Cryptomatte is wrong in the Picture Viewer
LeSill
Hello there,
I'm having an issue with cryptomatte layers. When I render it in Live Viewer, it appears to operate OK, but when I render it in Picture Viewer, it does not. It is completely shattered. I save it as EXR (Octane), so the format isn't an issue. Do you have any clue where the issue is?
please go to c4d menu Extensions/Console, (Shift+F10), and share a complete screenshot of the panel, or copy paste the default console output in your answer, thanks.
Please also share a screenshot from Render Settings/OctaneRender/Render AOV group tab, showing the Cryptomatte settings, thanks.
ciao,
Beppe
LeSill
Here is the log:
Bind to all slaves...
*Unknown state on slave:0:unknown state:0 IP:192.168.0.10
Connecting to slave:0:DESKTOP-EA2UTCB state:2 IP:192.168.0.10
**Slave is authenticating:0:DESKTOP-EA2UTCB state:4 IP:192.168.0.10
Slave is running:0:DESKTOP-EA2UTCB state:5 IP:192.168.0.10
Export materials time= 16021.074 ms
Collect objects time= 1.806 ms
Mesh creation time = 1245.213 ms.
MB:0/0 ST/MOV:0/101 Nodes:400 Tris:10.111m DispTris:0 Hairs:0 Meshes:106
Textures Grey8/16:0/0 Rgb32/64:29/0
VRAM used/free/max:3.578Gb/1.158Gb/8Gb Out-of-core used:0Kb RAM used:61.643Gb total:127.896Gb OpenGL free/total:0/0
mblurTM=0.055sec. createTM=0.067sec. updateTM=0.447sec. renderTM:145.796sec. totalTM:168.948sec.
Tonemapping the all passes tm:354.709
Displaying passes in tm=1315.951
SSmolak
I also noticed that Cryptomate doesn't work in Photoshop using EXR-IO plugin. It works only as separate material masks but not as all in one color image.
LeSill
SSmolak wrote:I also noticed that Cryptomate doesn't work in Photoshop using EXR-IO plugin. It works only as separate material masks but not as all in one color image.
I tried it with DaVinici Resolve, but it's worthless because the output is....well....unusable. I tried turning off the alpha channel and a few other things, as well as using the standard EXR format, but it didn't work.
I'm using version 2022.1.2 R3. Do you know if the same issue exists with a lower version?
LeSill
Because Resolve is the wrong tool. Fusion Studio (standalone) is the right tool (or Nuke).
I've previously used Cryptomatte in a DaVinci/Fusion page and everything went smoothly. In any case, the incorrect Cryptomatte layer generated in the Picture Viewer is unrelated to the postprocessing tool. It's an Octane/Cinema bug.
Has anyone else have this problem and fixed it?
ok, unfortunately the log is not complete, and the exact version of plugin used is not visible.,
Anyway yes, Picture Viewer result is not displayed correctly, but it is not important, since the saved result is correct with Photoshop and EXR-IO:
ciao,
Beppe
SSmolak
But why my cryptomates looks in Photoshop like this ?
Yes, cryptomate masks display fine in PS but you know that for large scenes you have dozens of different masks that is not good.
Cryptomatte offers automatic masking, and can be very useful, especially with complex scenes, but can be used in different ways, materials, geometry, objects, ecc.
So, based on the structure of the scene, you need to find the mode that better suits for your needs.
ciao,
Beppe
Nothing wrong with that in picture viewer. Crpyto colors are not one layer RGB data. What you see is in the LV that's just for your info with "false-colors", not for using in any compositing software. We call it as human-readable.
To see human-viewable crypto buffer that will broke the crypto colors for saved images. So your request is void for the Picture Viewer. You can check the colors in Live Viewer as always.
