Cinema4D version 2023.1-Beta3-R4 27.09.2023
Kalua
aoktar wrote:
SSmolak wrote:
Kalua wrote:This build looks great, Aoktar! THanks!
Until now I realized C4D background object is not exported to Octane SA.
I'm curious how you using C4D background object because it completely doesn't work for me. Why not to use Octane environment texture instead ?
Thank you Aoktar for fast update !
Background object is not something that can be exported
Yes! I realized now.
Octane User since V1 Beta
Kalua
C4D background object can be used and be useful in some cases - I use different backgrounds techniques according to my needs. I like to blend the background everytime I can to avoid alpha glitches in photoshop.
In the image I show how I use the background object:
it allows you to use 1 environment object for lightning, 1 environment for reflection, refraction, and the C4D background for guess what... background.
I never made it to use 3 Octane environments for light, reflection, refraction and background. It's not perfect but this would be one way to do it. There are other ways.
Regards,
C4D material with native image in clolr channel, applied to Background pbject
Render in viewport - alpha channel must be active in engine kernel settings
pandayoghurt
Is there a way to get C4D light linking working when using Analytic lights?
Seems to only work with Default or Primitive light types.
Also Analytic lights don't seem to work well with Light pass IDs either.
Is there a way to get them working correctly?
Many thanks
Kalua
pandayoghurt wrote:Is there a way to get C4D light linking working when using Analytic lights?
Many thanks
Light Pass IDs are working (analytic) here for me.
marcus1070
Chaos node is broken:
[string "Chaos texture"]:674: No pin "inputRGB" in nodes with type NT_TEX_OSL
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Nvidia driver version: 516.94
- Cinema 4d r25
- Plugin version Studio+ 2022.1(r7)
http://www.marcusrizzo.com
SSmolak
Kalua wrote:
C4D background object can be used and be useful in some cases - .......
Thank you for explanation. I see that you use C4D material for Background object - this is why it doesn't works for me while I was using Octane material.
Anyway month ago I prepared rig for that :
- using one slider you can change sky from clear to cloudy with proper Sun intensity, shadow softness and overall sky color cast
- sliders for rotating whole sky horizontally and vertically
- switchers for using two HDRI maps instead which works with these sliders above
- additional HDRI for reflection only
- additional image as background for reflection only with alpha mask - like city, tree line
- all of them have exposure, saturation, gamma, hue corrections
- all of them you can move up, down, rotate
- for all of them you can add special ground mask to add additional color with corrections
example video attached or it is here https://www.youtube.com/watch?v=_En4Qf7DZZg
Octane_Sky_Setup.zip
(18.28 MiB) Downloaded 211 times
marcus1070 wrote:Chaos node is broken:
Chaos texture is working here:
ciao,
Beppe
Kalua
I remember you mentioned it.
It looks really nice! I also find this Silverwing rig very useful! I use it oftenly: https://www.youtube.com/watch?v=q6BEgb9GmK4&
Would you sell it? I am interested.
james_conkle
ISSUE: Using latest c4d & octane R4 beta - after changing an area light to an analytical light if you use the octane light manager to make any adjustments or enable/disable a light it reverts to a primitive light type.
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
james_conkle wrote:ISSUE: Using latest c4d & octane R4 beta - after changing an area light to an analytical light if you use the octane light manager to make any adjustments or enable/disable a light it reverts to a primitive light type.
I'll try to fix it, thanks!
Return to “Releases”
