IES Emitters
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
JNDesign
Hi Paul
In the documentation you have mentioned that to control the direction of light from IES file, use "orientation" pin however the plugin doesn't have that pin.
Could you please clarify.
thanks
Hi - yes, the manual is out of date in this regard. The setup described at viewtopic.php?f=41&t=59870&p=382451 should work for you.
Return to “Autodesk Revit”
