Beta 2.2 RC1: Blender 2.55 Export Script testing thread
enricocerica
That's the problem I get using the 2.56 version, are you using a special build ? If so I suggest you use the official 2.55 version.
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
tungerz
Ahhh Yes,
I'm using my own builds, ever so often I update my svn and recompile a fresh daily build...
so revert back to BF'S official 2.55 release?
Okies, I'll give it a try.
Thanks again :)
Cheers,
Andy
Win7 64bit...Q6600 Quad core...8Gig Mem...9600 geforce...Daily Build Blender2.5x...Lionel's(Yoyoz)1.10 Blender Exporter... 0 Skill=Priceless
SamCameron
What I really miss right now is particle render as object or group, also group rendering, apart of this, the rest is working quite good with this exporter, congratulations to the developer, looking forward for more.
yoyoz
Hi Enricoerica,
I'm testing your plugin with Blender 2.56 on Ubuntu 64bits. It looks fine but I had to comment some stuff in order to get it working. I didn't test all features, but it already sounds very nice!
Do you have setup a 2.56-aware version yet so I can safely test?
Yoyoz
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
yoyoz
tungerz wrote: It did load in the render options, but it didn't work on exporting a render, I got errors.
I've attached a screen grab, hope that it helps and if not I will wait until a more stable version is available :)
Hi Tungerz,
you just need to replace render(False) with render() at line 1607 of your script. Worked for me with same error...
Yoyoz
tungerz
Hi Tungerz,
Yoyoz
Hi Yoyoz,
Many thanks my friend... gotta give it a test drive :)
Cheers,
Andy
yoyoz
Hi Tungerz,
it looks like you're missing lots of options in the render setup.
You can give a try to the attached script, you should get same as I have on this screenshot.
Cheers,
Yoyoz
engine_render_octane.zip
(15.97 KiB) Downloaded 294 times
Capture-Blender [-home-lionel-Documents-Blender-Scenes-Cessna-cessna_keyring.blend].png
tungerz
Negitive, Declined again :p
Different error
and mine was at 4 different placereplace render(False) with render() with noe at line 1607.
hmmmmm... I will do some investigating...
Here is some of the error dump... I won't post all of it as it is alot...
Your right, I am missing alot of stuff.... Don't tell my wife, she get a kick out of that :p
Thanks again for your time and knowledge :)
Cheers,
Andy
yoyoz
Hi Andy,
that's strange, I don't have any error. The only I forgot was the code for animation render. This is now fixed in this new script (look at attachement).
Cheers,
Lionel
[EDIT] updated script to better format animated picture names (img_0001.png instead of img_1.png)
(16.04 KiB) Downloaded 330 times
tungerz
Hi Yoyoz,
I will check it out when I get off work,
Which version of blender are you running? 2.55?
I deleted BF's 2.55 after they launched 2.56... and what a mistake that was :p
Thanks again my friend :)
Cheers,
Andy
Return to “Blender”
