Beta 2.2 RC1: Blender 2.55 Export Script testing thread
enricocerica
Here is the blender 2.55 exporter python script for beta 2.2 RC1, for testing:
octane_exporter_blender255_20101229.zip
(15.78 KiB) Downloaded 472 times
Limited to Blender 2.55 (See first thread for blender 2.49 version)
For Windows only (linux and mac will follow as soon as we get something more stable)
To install and use on Windows put the script in the appropriate script folder Blender 2.55 installation folder\2.55\scripts\io
Last changes since first version :
17/10/2010 :
Alpha 2.2.01 released for Blender 2.54
This is an alpha version, so expect several issues ;)
Still a lot of work, tries after tries, APIs changes after APIs changes the code became really messy. So I'll have to reorganize it a bit before proceeding and I need your first impression before adding other functionalities.
I would like to thank Livuxman for providing some good advises
What should work
Export only
Export and render still image
Export and render animation
For now it only exports meshes (didn't tested with other objects)
Unit size should be taken into consideration
Select and export camera
Select and export sun
Define and export resolution
Define and export lens aperture
Define and export focal depth
Camera motion (hope so)
What doesn't work (for sure)
Parameters are not saved
Select samples drop down (should be entered manually)
Some issues with selecting paths, should be corrected manually
GPU device to use (well I didn't tested it)
Probably other issues, just post the problems you may find
29/12/2010
Alpha 2.2.02 released for Blender 2.55
Mirror property were used to set the specular shader instead of transparency
Roughness map exported based on hardness mapping
Several fixes in material conversion
Other objects types are now exported (curve, text, meta, ...)
Check if camera is valid and selected when export camera is activated
Check if sun is valid and selected when export sun is activated
Set the "samples per image" according to the "presets samples per image" dropbox selection
Take all the advanced options into consideration for obj exporting
Fix issue with material assignment for curve and text objects
Now it should export duplicates as well as object and group particules
Still many things to do ...
Screen Shot:
Please keep all discussion regarding this script in this thread.
Enrico
http://www.myline.be
greg.thoman
Great! Thanks so much for your hard work!
AMD Phenom II X6 3.2 || 12 GB DDR3
GTX 480 1.5GB X 3 Liquid Cooled
RaidMax 1000W PSU || Corsair 850W PSU
MSI NF890-G65 Mainboard || Windows 7 64 Bit
steveps3
excellent! I can't wait to try it out.
(OS) Windows 7(64)
radiant
f!@# YES!!!! omg omg. going to test this baby out :D
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
steveps3
Initial tests, a big thumbs up! :mrgreen:
(OS) Windows 7(64)
PhilBo
Working good so far as well. I noticed that I had a metal that got exported as a specular material. There is nothing that I can see in the material settings in Blender that indicates it would be considered Specular. What do you use to determine if something is Diffuse, Specular, or Glossy?
Win7 64| Two GTX 470s | Phenom II 920 | 8 GB
Win7 32| GTX 260 | Athlon X2 5000+ BE | 2 GB
enricocerica
PhilBo wrote:Working good so far as well. I noticed that I had a metal that got exported as a specular material. There is nothing that I can see in the material settings in Blender that indicates it would be considered Specular. What do you use to determine if something is Diffuse, Specular, or Glossy?
Thanks Phil for testing, indeed I used the mirror property instead of transparency to set the specular shader, so here is the first bug reported ;), will be fixed in the next release. I use the specular value to set glossy or diffuse if it is equal to 0.
PhilBo
I also noticed that if the relative checkbox is checked when choosing a file path, the script fails. Can you put some check to ensure that absolute paths are selected, or to put some file path check into the script?
enricocerica
PhilBo wrote:I also noticed that if the relative checkbox is checked when choosing a file path, the script fails. Can you put some check to ensure that absolute paths are selected, or to put some file path check into the script?
Yep, paths selection is something that should be improved and indeed you may expect some problem with them, it's in the todo list ;)
Daniel
Thanks for the hard work you've put into this! It's something I've been waiting for which really was necessary.
Core i7 950 @3.07GHz | GTX 460 2GB | 12GB RAM | Window 7 x64
Return to “Blender”
