Shadow catcher showing when i apply materials...
Tigersan
As I switch to the HDR backdrop and switch the ground plane to a diffuse material and check the shadow catcher checkbox. The entire ground plane is showing its "shadow"? once I apply the materials to the character... before applying materials its all fine and the ground plane acts like it should, be invisible except the shadows... How to remedy that?
My Artstation profile: https://www.artstation.com/tigersan
Software: Poser 11 Pro, Octane Studio 2020.1.5.104, Adobe Suite
My RIG:
Operating system: Windows 10 Pro 64
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
HDD: 2x WD Gold 7.68TB U2 NVME
Hi. I am not clear on what you are trying to do here. Are you able to provide a scene which demonstrates the problem with a sphere instead of a figure please?
Tigersan
ShadowCatcherError_NoMats.png[/attachment]Im trying to have my character in the scene with HDR lighting and i wanted to use the ground as a shadow catcher. Otherwise it looks kinda silly without shadows. So the entire ground plane is visible as a shaadow, whereas it should be invisible. And it works just fine right up to a moment i apply all the materials so my model...
Here's the scene, i noticed it starts displaying incorrectly after i apply the armor mats, there are diffuse materials that are set to light emitters and all the rest are glossy... but whatever it is it shouldnt make the shadow catcher primitive visible in the render window...
https://www.dropbox.com/scl/fi/of3n8000 ... an64i&dl=0
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
Tigersan
Of course when I say it started displaying I meant in the render window... :)
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
Thanks. This scene is missing many many texture files, so I cannot load it. It is much easier if you can just give me a very simple scene with a sphere instead of a figure which demonstrates the problem,
Tigersan
The problem is that it doesnt happen with a simple sphere... :/
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
I am not sure there is a lot of help I can provide without a simple sample scene which demonstrates the problem. However, is it possible the SSS on the figures skin is causing the issue? Or perhaps the figure is touching or going through the ground plane?
Tigersan
Hmm no because when just the figure is there with loaded maps, with SSS and all, but the armor doesn't have maps loaded yet it's ok then. When I load the mats to the armor thats when the ground plane becomes visible. Armor has 2 types of mats glossy, and diffuse emissive mats.
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
Tigersan wrote:Hmm no because when just the figure is there with loaded maps, with SSS and all, but the armor doesn't have maps loaded yet it's ok then. When I load the mats to the armor thats when the ground plane becomes visible. Armor has 2 types of mats glossy, and diffuse emissive mats.
Again, I am guessing here, but perhaps the emissive materials are causing an issue?
Return to “Poser”
