First Interior with Octane
Forums: First Interior with Octane
Postby Conna3005 » Mon Jun 19, 2023 11:00 am
Conna3005 Mon Jun 19, 2023 11:00 am
Hello everyone.
I am starting with different Tutorials for Cinema 4d and Octane Plugin.
I would like to get a better Result at the Walls. I really need a Displacement Map with a Wallpaper of Rough Surface.
I finally was getting this Kind of Lighting in the Scene. Far better than my Resusts with other Renderer.
I need some advise at the Interior and the Skin and Cloth for my Character. I am preety new to the Functions of Octane for Cinema 4d.
Especiely The Setup for the Lights and the SSS Settings would be Helpfull.
Here are my Screens.
WIP 2
WIP 1
Conna3005
Re: First Interior with Octane
Postby Conna3005 » Sun Jul 23, 2023 4:09 am
Conna3005 Sun Jul 23, 2023 4:09 am
I have testet the ACES Settings for Interiors.
At least i got a little understanding of Linear and SRGB Settings.
I use the Actual ACES Plugin.
This is my actaul Result. I have Exposure 10. The Lights are weak set.
Conna3005
Re: First Interior with Octane Actual Status
Postby Conna3005 » Wed Jul 26, 2023 3:55 pm
Conna3005 Wed Jul 26, 2023 3:55 pm
I got a little exercise on the Color Formats.
I would like to know how i can make the Walls more realistic. I cannot find any Wallpaper Texture. At least not the Dispalcement Texture for raw Wallpaper.
Here are my actual Screens.
Conna3005
Postby frankmci » Wed Jul 26, 2023 4:20 pm
frankmci Wed Jul 26, 2023 4:20 pm
You might want to look into bump and normal mapping before you try displacement on your walls. It is a subtle enough effect that you really don't need to pay the price of all those extra polygons.
If you have some real-world examples of what you are looking for, we might be able to make some better suggestions.
Technical Director - C4D, Maya, AE, - Washington DC
frankmci
Postby Conna3005 » Sun Jul 30, 2023 6:15 am
Conna3005 Sun Jul 30, 2023 6:15 am
I modified the Lightning and gave the Room some Displacement.
The Displacement is a Hard Piece of Work.
At least it is better. I work with the Denoiser and had to Setup the Blur.
Maybe you got some Tips.
Conna3005
Postby Conna3005 » Fri Aug 11, 2023 3:21 pm
Conna3005 Fri Aug 11, 2023 3:21 pm
So finally here is my actual Status.
After understanding the Setting of the Lights i got a Step foreward.
I still have a Problem to set the Bump map. The Light is a very delicate work.
Check the renderings and give a hint how to set the Lights settings.
Conna3005
Postby Conna3005 » Fri Aug 25, 2023 3:41 pm
Conna3005 Fri Aug 25, 2023 3:41 pm
I have some Troubles to Setup the Walls rightly with a Noise Shader.
I got only big Shades of the Bump and cannot get it smoother and smaler.
Would be a Baked Texture better, or do i get somewhere a Rough Wallpaper Bump/Displacement Shader ?
The other Shaders of the Object are no Problem. I need a good Advice at the Walls. Here i use a Bump Map.
Conna3005
Postby Conna3005 » Sat Aug 26, 2023 6:30 am
Conna3005 Sat Aug 26, 2023 6:30 am
Well, this is my actual Final.
I have to work on the Warm and Blue Light Setti9ngs. At the moment i ahve a Hard White Lighting.
At leat in Cinema 4d 2023.2.2 there are Rought Wallpapers in teh Asset. I had first to Set the right Blur of the Screen.
300 Samples
Diffuse/Specular 10
Rendertime 2.12 Min.
Conna3005
Postby Conna3005 » Mon Oct 02, 2023 2:24 pm
Conna3005 Mon Oct 02, 2023 2:24 pm
Final at least.
I opened a Wall and let some Light into the Room. I would have to figure out how to make a Interior Animation if i have multiple Angles.
Here is my actual Status. It ws a lot easier as soon i opened the Wall.
Conna3005
Return to Works In Progress
Users browsing this forum: No registered users and 5 guests
Thu May 23, 2024 4:22 am [ UTC ]
cron
