Cinema4D version 2023.1-Beta1-[R1] 20.07.2023
SSmolak
aoktar wrote:I've updated the build to Beta 1 version. Enjoy it!
Thank you for fast update !
But please see video :
ocatne_material_cocking_viewport.zip
(166.03 KiB) Downloaded 161 times
Not sure what are you showing, something strange on you again! Please create a help ticket from the Octane support.
SSmolak
aoktar wrote: Not sure what are you showing, something strange on you again! Please create a help ticket from the Octane support.
Try to turn off any object while material node is active in node editor. Edit controls must be turned on.
eyeonestudio
WINDOWS STUDIO+ BUILD (R19-R2023)
https://render.otoy.com/customerdownloa ... R1_win.rar <--- LINK Not Working
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
eyeonestudio wrote: WINDOWS STUDIO+ BUILD (R19-R2023)
Checked that is working fine!
SSmolak
This is caused by turned off material previews option :
Zrzut ekranu 2023-07-20 115246.png (10.69 KiB) Viewed 2511 times
After that if material node is selected there is no way to turn off objects in scene. Also some other live updates function doesn't work.
If you disable these two options then some functions will not work fine. Keep these are enabled
Amaterasu
Aoktar, please tell me if there are any plans to add a realtime denoiser,
Amaterasu
Directlight does not change its position depending on the rotation, it ignores position changes
SSmolak
Hue parameter from Color Correction node doesn't work at all.
Return to “Releases”
