EXR not being saved with full dynamic range
Forums: EXR not being saved with full dynamic range
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
Postby Dingbat » Tue Jun 27, 2023 6:19 pm
Dingbat Tue Jun 27, 2023 6:19 pm
i've tried 16 and 32 bit exr options but any values above 1.0 intensity are clipped to 1.0
the image isn't linear either it's gamma corrected when i open in Fusion or Affinity Photo
the same image exported from MODO works as expected
Dingbat
Re: EXR not being saved with full dynamic range
Postby elsksa » Wed Jun 28, 2023 2:21 pm
elsksa Wed Jun 28, 2023 2:21 pm
Is "Force Tone Mapping" Enabled?
elsksa
Postby Dingbat » Wed Jun 28, 2023 5:46 pm
Dingbat Wed Jun 28, 2023 5:46 pm
ACES/Force Tonemapping/Highlight Compression all disabled
is it working for you?
Dingbat
Postby Dingbat » Wed Jun 28, 2023 6:34 pm
Dingbat Wed Jun 28, 2023 6:34 pm
Dingbat
Postby Dingbat » Wed Jun 28, 2023 6:42 pm
Dingbat Wed Jun 28, 2023 6:42 pm
same process but rendered in MODO:
Dingbat
Postby elsksa » Wed Jun 28, 2023 10:28 pm
elsksa Wed Jun 28, 2023 10:28 pm
I don't know where that EXR has been loaded to be viewed.
Has it been conformed to display output? From Linear-sRGB to non-linear sRGB?
A linear-sRGB EXR is not supposed to be viewed without a conformation to a given output destination.
A relatively short read on the fundamentals of an interminable yet crucial topic.
elsksa
Postby face_off » Thu Jun 29, 2023 7:01 am
face_off Thu Jun 29, 2023 7:01 am
For reference, saving an EXR saves with the following settings:
- sRGB color space
- No pre-multipled alpha
- Zlib compression, in blocks of 16 scan lines (lossless)
- Compression level of 45
There is an option to save as "The sRGB color space with a linear transfer function." (ie. Linear) - however that would apply to all saving of EXR's. Linear is potentially the better default for EXR's. Let me know if you would prefer that.
Postby Dingbat » Thu Jun 29, 2023 9:08 am
Dingbat Thu Jun 29, 2023 9:08 am
elsksa wrote:I don't know where that EXR has been loaded to be viewed.
thanks
i understand that a linear EXR is not supposed to be viewed natively. i was showing the linear image to point out the difference vs the tonemapped Archicad output
i should add that i wrote "the image is rendered in MODO" but of course i meant Octane for MODO
the post processing app is Fusion Studio. my usual workflow is very simple - export a float 16bit linear EXR and tonemap as required
same image from above tonemapped:
Dingbat
Postby Dingbat » Thu Jun 29, 2023 9:14 am
Dingbat Thu Jun 29, 2023 9:14 am
face_off wrote:There is an option to save as "The sRGB color space with a linear transfer function." (ie. Linear) - however that would apply to all saving of EXR's. Linear is potentially the better default for EXR's. Let me know if you would prefer that.
yes please from me
those that prefer tonemapped have the png option, or can use the Force Tonemapping option (which should give the same result as what we have now?)
Dingbat
Postby elsksa » Thu Jun 29, 2023 12:20 pm
elsksa Thu Jun 29, 2023 12:20 pm
yes please from me
I second this. EXR out of a renderer should always be encoded linearly in "HDR" (Octane jargon for 16-bit floating point high dynamic range specifications).
I would even warn on PNG, as there are far more suitable alternatives (as covered here).
elsksa
Next
Return to Graphisoft ArchiCAD
Tue Jun 04, 2024 12:48 pm [ UTC ]
