Disable the Denoising Pass.
Optimizing your scene can really help with this. You are running out of VRAM in this situation.
Cinema4D version 2022.1.1-R6 (Obsolete stable) 08.07.2023
- jayroth2020
Hi,jayroth2020 wrote:Disable the Denoising Pass.
this happens also with smaller Scenes. VRam is not the problem!
I encountered those problems in combination with AOVs and Denoiser since longer time.
Hope, this will be fixed soon!
thanks
Mike
- jayroth2020
The more Octane needs to hold in VRAM, the more of a potential issue VRAM usage becomes. So did you try disabling Denoiser for this situation? If so, what was the result?
- jayroth2020
You'd have to send in your scene to [email protected]; use File > Save Project with Assets... archive the result, and send it in, along with your ticket.
Hi again,
suddenly, after updating C4D to 2023.2.2 my viewport is completely black.
Every Object with any Octane-Material appears black in the viewport.
I can only see whats goining on when I switch to "layer-color-view" or "lines mode".
Any idear, what could cause that?
thanks
Mike
thanks
Mike
Viewport or materials in the viewport? Both are not same thing.miohn wrote:Hi again,
thanks
Mike
every object in the viewport whis has an octane material appears black.aoktar wrote:Viewport or materials in the viewport? Both are not same thing.miohn wrote:Hi again,
thanks
Mike
So I have a stage-object and 2 other objects on the stage (f.e. my startscene "new.c4d") and all is black
Works finemiohn wrote:Hi again,
Mike
Your viewport is fully filled by objects, so viewport is not black. Covered objects are with black textures. Spend some time to play with content to gather more info.miohn wrote: every object in the viewport whis has an octane material appears black.
