Systemlink to LocalDb bugged ?
sevengreen
Hej,
is it possible that the LocalDb specific Folder for the LocalDB via Modo is bugged ?
If i click the [Live DB/ Local DB] > [Import] insinde Modo Octane-View it opens a different Folder from what i set in System> Prference> Octane> LiveDB
It Links to Users\xxx\AppData\Roaming\OctaneRender\localDb // Preference is set to: "D:\_assets\material_octane"
in Octane Standalone it is set to "D:\_assets\material_octane" as well and works as aspected.
Win 11Pro 22H2 22621.1848
Modo 16.1v4
Octane 2022.1.1.190 Studio+
Import Button inside Modo
Modo Path
Modo Path
Octane Standalone Path
Screenshot 2023-06-16 145720.png (4.02 KiB) Viewed 1358 times
Hi
The plugin LiveDb Texturemaps Folder is the folder where LiveDb texturemaps are unpacked and stored.
The LocalDb folder is where the Octane LocalDb material are stored. The LocalDb window is a popup generated from within the Octane SDK, so I have queried OTOY on how to change the folder. I will report back here when I hear more.
Return to “Foundry Modo”
