Gradient Map node corrupted after grouping
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Andreas_Resch
There's a bug with the Gradient Map node when including it in a group. If you create the group, it still works in the same session. But once you save the file and open it again, the Gradient Map node is corrupted. Consequently Blender crashes when you try to open and render a scene that has a Gradient Map node in a group. Attached is an image of the corrupted Gradient Map node.
Reproduce ...
*) Create a Garient Map node
*) But it in a group
*) Save and load the scene again
*) Look inside the group
It would be great if you could fix that. Cheers.
linograndiotoy
We're taking care of this, thanks for your report!
Return to “Bug Reports”
