Camera Projected Texture Displacement
Hi, is there a way to use an image displacement on a texture which is camera projected? I can get the material to project correctly, but the displacement doesn't use the same projection. It's also an animated texture... but I've just included the first frame as the projection is my issue. File attached for ref - thanks all!
- Camera_Projection_Displacement.zip
- (1.31 MiB) Downloaded 121 times
Win 10 64 | Geforce RTX 2080 x3 | i7 5960X | 32GB | Cinema 4D R21 | Octane 2019.5
you need to switch from Texture Displacement, to Vertex Displacement, and add a couple of extra subdivisions: ciao,
Beppe
P.s: avoid to use .PSD textures.
Beppe
