Cinema4D version 2022.1.1-R6 (Obsolete stable) 08.07.2023
J.C
Visible on scattering volumes
is missing in Octane emission in latest R5 build.
System – Windows 11
miohn
shaddam wrote:
baghbanikm wrote:why in this version , ican't render finally and don't save my Passes in EXR(octane)
always my render stuck in passes render
i have had this when using custom AOV's / comping in octane, i originally thought it was a deadline issue but turning off "show passes" when doing the final render seems to fix this issue, using 2022.1.1-r4
Good Tip!
Need to watch this a bit longer, but unchecking "show passes" seams to fix this problem!
Mike
J.C wrote: Another effector that is very easy to track. Octane area light. When it is present it causes restarts when clicking objects in Object manager. When the light is disabled it does not restart.
I think you didn't understand the logic and problems on my explanations. Do not spend your time with these, nothing to do on this topic. Just disable geometry updates if you don't want a restart on rendering.
J.C
I've tried the same simple scene in RedShift in C4D. Restarts doesn't happen in Redshift the same as in Octane.
System – Windows 11
Please share your simple scenes, I'll compare with RS
J.C
My scene has two boxes, one plane and one Octane area light. This is my simple scene where the issue happens.
System – Windows 11
J.C wrote:My scene has two boxes, one plane and one Octane area light. This is my simple scene where the issue happens.
We don't this issue with very simply scene like you say. Please record a full screen video to show it
J.C
Here is video with the issue and C4D file I used to illustrate this.
refresh issue.mp4
(6.46 MiB) Downloaded 1559 times
update issueC4D.zip
(79.02 KiB) Downloaded 122 times
System – Windows 11
mingmingAS
This version cannot output multi-channel
Aleksei
The render layer option doesn't work in this release.
In this example render the cude on the left has Layer ID 2.
RTX 4090 | Ryzen 9 7950X3D | 64GB | Win 11 23H2
Return to “Releases”
