OC different version, white color
kylin_1
I made the project in OC2020 before, the same project, now after opening in OC2021, the color of the preview window is white, how can I restore the normal color?
if you are using the c4doctane plugin, you need to go to c4doctane Settings/Env tab, to personalize the default Environment color:
ciao,
Beppe
kylin_1
Thanks for your reply, my problem is actually: for example, in my OC2020 project, the color of the wood panel is normal, but when I open the same project in OC2021, the color of the wood panel turns white.
kylin_1
thanks!
Yes, from 2021.1 it is possible to specify the Color Space for each texture. You need to go Live View menu materials/Octane Texture manager, and check that the Color Space is not set to No-color data, then change it to Linear sRGB-Legacy Gamma.
in 2021.1 there is also a new White Light Spectrum menu in the kernel panel, and by default is set to D65.
You need to switch to Legacy/Flat to have the same result as before:
ciao,
Beppe
kylin_1
However, do I have hundreds of image textures to modify one by one, and is there a batch way to modify them uniformly
have you tried via Live View menu Materials/Octane Texture manager?
You should be able to select multiple textures, and change the Color Space in one go.
ciao,
Beppe
kylin_1
Thank you for your reply. I have tried to make bulk modifications like this, but as shown in the picture, the interface will be messy, with at most a few shaders to modify, which will take a long time. Unable to modify with one click.
kylin_1
OMG,Thank you so much!
Return to “OctaneVR Questions & Discussion”
