Cinema4D 2022.1-[R10] (Previous stable) (26.03.2023)
thanulee wrote:can we fix denoised pass when saving from LV to be in ACES as well? thanks
Fix? You can save it, see this pic
thanulee
Oh thanks, I meant when you right click on the bottom and try to save. Could you default these too to ACES?
thanulee wrote:Oh thanks, I meant when you right click on the bottom and try to save. Could you default these too to ACES?
Why should I do it default? Is everybody using ACES?
thanulee
Yes u are right maybe some dont use ACES. Although thats the only industry standard by now.
Eg. Redshift has ACES default doesnt give you options to go to previous colorspaces.
I think in octane 99% of users use ACES too.
Maybe add a menu "save as aces" and "save as srgb" as the "png linear" doesnt make much sense eitherways, nobody comps linear 8bit.
Either exr or png 8bit is a normal workflow.
FxDesign
Speaking of ACES, how can I preview a LUT/Custom LUT when "ACES tone mapping" is activated (in the camera tab) ?
It doesn't seems to be working.
FxDesign
FxDesign wrote:Speaking of ACES, how can I preview a LUT/Custom LUT when "ACES tone mapping" is activated (in the camera tab) ?
Hello ?
Hello ?
It's not a plugin related limitation
RTF
Does anyone know why the Dirt node does not respond when connected to bump or normal?
The previous version was working
Is this a bug?
RTF wrote:Does anyone know why the Dirt node does not respond when connected to bump or normal?
Is this a bug?
Are you sure?
Which exact previous version?
This is a core limitation, and shouldn't work in any versions.
You should need to have proper unfolded uvs, then use the Baking Camera to bake the Dirt to texture and save it to disk, then use it in your materials for Bump or Displacement.
ciao,
Beppe
RTF
Is this a bug?
Are you sure?
ciao,
Beppe
Someone in the forum has asked this question, when aoktar replied to the video inside the demonstration is possible
viewtopic.php?f=30&t=78897&p=407842&hil ... mp#p407842
Return to “Releases”
