Volume displacement in Houdini ?
Houdini Integrated Plugin
fantome
Hi guys,
I would like to know if volume displacement is supported in Octane for Houdini ?
I know it can be done in standalone and C4d but i am not sure on how to proceed in Houdini.
The C4D process :
https://www.youtube.com/watch?v=xI9Ivq58vZ8
basically i would like to shade particle with a volumetric shader to get perfect spherical volumetric sphere,
and then displace those sphere in object space to deform the sphere to get closer to a snow pattern.
basically i want to replicate the afterburn or binary alchemy workflow to create some snow.
binary alchemy shader that shade particle with displaced volumetric sphere :
https://web.archive.org/web/20150606082 ... videos.htm
PT_textured_per_particle_lowres.mov
(684.62 KiB) Downloaded 1695 times
afterburn for max, that can shade particles with octane volemtric displace.
https://www.afterworks.com/AfterBurn.asp
Thanks for your help
Cheers
E
juanjgon
What do you think is missing to follow the C4D tutorial in Houdini?
galleon27
Here you go. I've attached a file.
It's pretty much the same process as standalone and C4D. There is no Octane Volume object like in C4D because that would be redundant. You can make the same thing with Houdini nodes. There are multiple ways of doing that but its a lot easier to just search how to create volumes inside Houdini than for me to explain. But basically you can either convert an object into a volume or you can convert particles into volumes. I've done both in the file i shared.
volumeDisplace.zip
(262.39 KiB) Downloaded 170 times
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
fantome
Thanks a lot for the very fast answer guys.
my bad it's great to see that octane for houdini can also do volumetric displacement.
here is a feature that can't be done in the other GPU engine that some of you know quite well here. ;)
thanks a lot for sharing your knowledge galleon27 !
galleon27
Some useful information regarding volumes/vdbs inside Houdini:
viewtopic.php?f=102&t=80091&p=413891#p413860
viewtopic.php?f=101&t=80886&p=419689#p419689
fantome
thanks a lot for the extra info ! 8-)
Return to “Houdini”
