C4D 2023 Freezes after renaming an object
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
GiWest
A. Windows 10 Home 22H2 (OS Build 19045.2604)
B. RTX 4090
C. 48GB RAM
D. Nvidia studio driver DCH 528.49
E. OctaneRender Studio 2022.1
F. Octane Render plugin version 2022.1 R7
G. Cinema 4D 2023.1.3
H. Whenever i want to rename an object WHILE the live viewer is active, C4D completely freezes. No bug reports, no errors. Just a dead freeze as soon as i rename and hit enter.
I think i have narrowed down the issue and it has to do with me docking octane into my layout. I have tried to completely remove C4D preferences folder and start over. With default layout everything is normal. But when i start docking octane elements and slowly rebuild my layout, at some point the issue come back. I found that if i pause the live viewer, stop and reset data, then go to rename an object - it works. I fire up live viewer back up and continue. Sometimes typing in gibberish works, but actual words cause a crash. I cant work like this, it's ridiculous.
A few months ago i upgraded from R21 and ever since 2023.0.0 i have had this issue, tested with multiple versions of octane. Been stuck on R21 since. I have not tried other C4D releases.
Scene and layout files here
Recording of the issue:
In my testing i have mostly been trying to rename a light to "x_highlight", but renaming any object kills it.
I hope you'll be able to reproduce the error
octane 2022.1 230301 225811.log
(870 Bytes) Downloaded 195 times
I'm looking to it, I suppose something changed in C4D side and bugging us. It's happening on dual layouts as I can see. Hold on....
Could you check with latest(2022.1-R8) build?
GiWest
Still freezes unfortunately
GiWest wrote:Still freezes unfortunately
It's happening if you have "Project Asset Manager". I don't know the reason yet, but I'll test it more.
GiWest
It is!!! Thank you so much! I can finally fully transition to C4D 2023 now. Hope you find the reason that's causing it.
14bmwc780nike
Confirmed. Updated my layouts no longer include the Project Asset Manager and zero crashes.
H: C4D 2025 | Asus ProArt X870E-CREATOR | Win 11 64bit Pro | AMD R9 7950X3D 4.2z 16-Core | 96GB | 3070ti/3090
W: C4D 2025 | Asus WRX80E-SAGE| Win 11 64bit Pro| AMD TRPRO 5965WX 24-Core | 128GB | 3090Ti
Cheers,
Marcus | 3dconge.com | @RockingThePIxel
Vivimagic
Good to know that a work around exisits. I can confirm I am having issues with 2022.1 r10 of Octane and only happens when the live viewer is on and rendering.
nycjunglist
I've had this issue for the past few days in 2023.2.0. I only noticed it recently since I primary use S24. From my tests, it looked like the problem happened after Octane was initialized, be it from opening and closing the Live Viewer without rendering, or simply creating an Octane material without assigning it to anything.
Removing the Project Asset Inspector from my layout immediately solved the issue.
Ryzen 9 5950x | 128 GB RAM | 5090 + 3080Ti
nycjunglist wrote:I've had this issue for the past few days in 2023.2.0. I only noticed it recently since I primary use S24. From my tests, it looked like the problem happened after Octane was initialized, be it from opening and closing the Live Viewer without rendering, or simply creating an Octane material without assigning it to anything.
It's that when Project Asset Inspector is hidden
Return to “Bug Reports”
