Cinema4D 2022.1-[R10] (Previous stable) (26.03.2023)
SSmolak
Can you add "external" button to load external OSL code in OSL Projection node like it is in standard OSL texture node ?
Manipulating weight map by C4D scene node ( capsule ) updates in Octane LV constantly but doing the same by manipulating UV require disable/enable capsule to show update in LV
marcus1070
Is this the way hair rendering works or is something with this version? I'm trying to get a full radius tube, but it sems to taper the last segment, this only happens when the spline is closed, when is open, it keeps the same radius on the start an the tip
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Nvidia driver version: 516.94
- Cinema 4d r25
- Plugin version Studio+ 2022.1(r7)
http://www.marcusrizzo.com
jayroth2020
Make your rectangle editable, and try again. Octane does not like primitives...
marcus1070
jayroth2020 wrote:Make your rectangle editable, and try again. Octane does not like primitives...
Same thing, like i said, it only behave like a tube on an open if i make the splines open
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Cinema 4d r25
divasoft
This bug not dependent from this. It has been present for many years, from the very beginning of the introduction of hair. It occurs if the spline is closed.
marcus1070 wrote:Is this the way hair rendering works or is something with this version? I'm trying to get a full radius tube, but it sems to taper the last segment, this only happens when the spline is closed, when is open, it keeps the same radius on the start an the tip
It's a bug on my side and will be fixed for R8.
marcus1070
Thanks Aoktar, another small issue on splines: The hair tab is not appearing at object tags on procedural splines that are inside of a cloner
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Cinema 4d r25
Another Minor update(R8) is out. Enjoy it!
thanulee
Thanks for the fixes :))
thanulee
Found a small glitch in HSV ui.
Saturation doesnt change to the above hue.
https://www.dropbox.com/s/djkczdu5e86np ... .webm?dl=0
Cheers!
Return to “Releases”
