Maxon 2023 or Octane bug? Crash when LV is open
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
14bmwc780nike
Not sure if this is a Maxon bug or otherwise. Repeatable and only showing up in 2023 not R23.
1. With the Octane Live Viewer open and running, create a primate or new material
2. Double-click the name of the object or material in their respective managers.
3. Type a new name for either an object or material
4. Press return and Cinema will wedge
5. Open task manager and end process
It appears this only happens when the Octane Live viewer window is open. If I close the Live Viewer, I can rename files in the Object Viewer and update color values with a problem. Once I open the Octane Live Viewer, that's when the bug appears, and only wedges Cinema once I hit the return key.
The Octane log viewer doesn't report anything when the crash/wedge happens. Here's a paste regardless:
Started logging on 25.02.23 12:23:26
OctaneRender Studio+ 2022.1 (12000020)
VRAM used/free/max:0Kb/8Gb/8Gb Out-of-core used:0Kb RAM used:13.945Gb total:63.874Gb OpenGL free/total:0/0
FumeFx library initialisation error!
Export materials time= 5176.074 ms
Collect objects time= 6.431 ms
Mesh creation time = 403.073 ms.
Api update time: 10.013 ms.
VRAM used/free/max:1.258Gb/3.996Gb/8Gb Out-of-core used:0Kb RAM used:18.207Gb total:63.874Gb OpenGL free/total:0/0
Export materials time= 56.059 ms
Collect objects time= 6.04 ms
Mesh creation time = 68.848 ms.
Api update time: 7.989 ms.
VRAM used/free/max:1.261Gb/4.371Gb/8Gb Out-of-core used:0Kb RAM used:16.126Gb total:63.874Gb OpenGL free/total:0/0
could not pick, because we have no render threads available
Export materials time= 56.021 ms
Collect objects time= 4.005 ms
Mesh creation time = 68.414 ms.
Api update time: 4.383 ms.
VRAM used/free/max:1.261Gb/4.256Gb/8Gb Out-of-core used:0Kb RAM used:18.013Gb total:63.874Gb OpenGL free/total:0/0
GPU driver version is the same on both systems; 31.0.15.1740
All Octane plugins are current.
Cinema _BugReport.txt attached.
_BugReport.txt
(892.7 KiB) Downloaded 164 times
H: C4D 2025 | Asus ProArt X870E-CREATOR | Win 11 64bit Pro | AMD R9 7950X3D 4.2z 16-Core | 96GB | 3070ti/3090
W: C4D 2025 | Asus WRX80E-SAGE| Win 11 64bit Pro| AMD TRPRO 5965WX 24-Core | 128GB | 3090Ti
Cheers,
Marcus | 3dconge.com | @RockingThePIxel
It looks like a plugin crash but not pointing to Octane. Do you have another plugins installed? Could you please record a video of full interface to show the operation?
do you have a custom c4d layout with c4doctane panels inside?
If yes, please try to delete it, and rebuild it from scratch.
ciao,
Beppe
14bmwc780nike
bepeg4d wrote:Hi,
ciao,
Beppe
Whoa, this is EXACTLY it! THANK YOU! Why? What's going on with the custom layout that causes this?
Cheers,
14bmwc780nike wrote: Whoa, this is EXACTLY it! THANK YOU! Why? What's going on with the custom layout that causes this?
We cannot know without seeing your custom layout. There may be some untested exceptions occured, please send us the your crashing layout.
14bmwc780nike
Aoktar,
Here is the layout. Thank you, for looking into this.
Conge_Dual_4k_2023.zip
(56.94 KiB) Downloaded 141 times
Cheers,
14bmwc780nike
Pointing to this post as the solution lies with no having the Project Asset Manager open when the live viewer is open. viewtopic.php?f=86&t=81299
Cheers,
Return to “Bug Reports”
