Color Vertex Attribute question
Houdini Integrated Plugin
Futureboy
Hi everyone!
I noticed that the node "Color Vertex Attribute" only imports two the custom attributes. If I promote through Ocatane objParms a third attributed with geometry it is not read. Example myCustom_1, myCustom_2, myCustom_3(this is not evalueted by the shader).
The attributes I'm promoting are color vector3
On the documentation is not specified how many attributes I can export.
It that confirmed or I'm missing something that I have to check?
G
galleon27
You're not missing anything. There is a maximum number but i don't remember what the maximum is.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
juanjgon
Yes, sorry. Octane only supports four float and two vector/color attributes simultaneously.
Futureboy
Ah OK! I will use those available wisely then! :)
Thanks for the heads up!
G.
adrianr
Are there any plans to increase that limit Juanjo?
Windows 11 | 14900k | 2 x 4090 | 96gb DDR5.
juanjgon
Nope, as far as I know.
Return to “Houdini”
