*** Intermediate DEMO release 0.8 alpha windows & linux ***
Is it possible that Octane v0.7 and v0.8 render differently? In the first attached image, the upper half is rendered with v0.8, while the lower half is V0.7. Both are rendered with path tracing turned on.
Also in v0.8, I can see no difference between using path tracing and using direct lighting:
What am I doing wrong/different here?
EDIT: just noticed you're using it wrong.
you don't add and click on nodes like pathtracing/directlighting to switch to them.
you change it by changing the node used in the preview macro.
eg, doubleclick on the node named 'macro' on the left, then change the node there by swapping it.
first image:
top image is directlighting
2nd image is path tracing
the 2nd image:
both images are directlighting
Radiance
first image:
the 2nd image:
Radiance
Thanks, that should do it.
For next demo, maybe is to consider putting subsampling default to 4x4 (or whatever the last icon on the right is) to make it navigate faster?
tnx
tommy5
tnx
tommy5
Win 7 32bit | Core 2Duo E6550 @ 2,33GHz | 4GB | Geforce GTX260 Core 216
When is the MAC version going to be released?
Hi,abedsabeh wrote:When is the MAC version going to be released?
We're nearly finished with the final linux port,
once that chapter is closed, we will make a mac port.
It should be available during the next few weeks.
Yours,
Radiance
- d.welshhons
radiance wrote:EDIT: just noticed you're using it wrong.
first image:
the 2nd image:
Radiance
Ah...so that is why I didn't notice any difference between the two either and thought the previous beta was actually giving better results as well.
System Specs: Windows XP Pro x64, ASUS P5QL PRO, Intel Core 2 Quad 3.00 Ghz, 7 Gb Ram, EVGA GT240
when will you release a version 1.0?
Thx for answer
Thx for answer
Win XP64, Q6600 , 8GB RAM, Nvidia 260 GTX www.lukashanak.eu
