oc 2022.1 refresh problems
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
jin384219328
Every time refresh there is not correct color in the viewport.Don't konw what's problems.
And the render is not correct.
setup:
windows 11
cinema 4d 2023/cinema 4d R23
RTX3090
octane 2022.1
NVIDIA Studio 526.98 driver
2022-11-29 13-58-13.mp4
(91.08 MiB) Downloaded 1067 times
Coherent_ratio should be 0. Version converter is doing a convert to coherent_ratio when open any scene. Your template scene is causing this most likely. Make a new scene and save as "c4d.new" as you did in past. Then coherent_ratio will be 0 by default.
jin384219328
aoktar wrote:Coherent_ratio should be 0. Version converter is doing a convert to coherent_ratio when open any scene. Your template scene is causing this most likely. Make a new scene and save as "c4d.new" as you did in past. Then coherent_ratio will be 0 by default.
Thanks~!It work~!
jin384219328
bepeg4d wrote:Hi,
please have a look at this discussion here:
viewtopic.php?f=30&t=80848
ciao,
Beppe
Thanks a lot~!
Return to “Bug Reports”
