Cinema4D version 2022.1-RC1-[r2] 07.11.2022
SSmolak wrote: It would be very great that Scatter object tag nodes works fine with possibility to delete them because they greatly improve scatter possibilities not only for distribute objects stack by noise but also individual object in scatter stack would have its own random scale, position and rotation parameters driven by main distribution noise. This is not possible in any other instancer in C4D like Cloner, Surface Spread or Forester.
All about node previews, it will work fine if you disable previews of nodes for scatter objects. Also I found the problem of deleting nodes with scatter. I'm trying to fix all
SSmolak
aoktar wrote: All about node previews, it will work fine if you disable previews of nodes for scatter objects. Also I found the problem of deleting nodes with scatter. I'm trying to fix all
Thank you very much ! I always have disabled node previews. I think that this version RC1 has little problems with updates compared to previous. It's looks like Octane has limited "window-timing" for checking scene updates because it update if something was changed fast ( fast slider mouse move ) but when moving slider is longer it update partially and do rest of the updating about seconds later. I mean object changing like scale, move mainly when they are part of Scatter. Materials updates works fine.
Also maybe there is way to add shortcut for disable node like solo node ? :)
After changing Camera Imager OCIO view to different, camera exposure in Octane LV is reset to 1 - but only in LV viewer.
Now OSX Prime builds are ready to roll. See the first page for download links.
dynaraton
This release is very stable and works faster overall. Thank you very much!
Asus Prime Deluxe II : Intel i9-10900 X : 128GB G.Skill 3600 MHz DDR4 RAM : (2) Nvidia RTX TITANs w/ NvLink : Win11 Pro : Latest Cinema4D
dynaraton wrote:This release is very stable and works faster overall. Thank you very much!
thank you
y81r
this behavior is only since RC1, not sure why!?
Win10
r26.107
Studio Driver 517.40
y81r wrote:this behavior is only since RC1, not sure why!?
Win10
r26.107
check coherent_ratio in kernel
y81r
Win10
r26.107
That did the trick, thank you!
why is this set by default to 1?
y81r wrote:
Win10
r26.107
Default should be 0.0. Check it please, you may have a "new.c4d" which is done with older plugin. And it now converts the coherent values to new one. You'll need to make a new "new.c4d" scene.
Kalua
y81r wrote:
Win10
r26.107
On Phototracing kernel my default Ray Epsilon is set to 0.1. I have no presets with this kernel whatsoever.
Other XB presented same behavior.
Not big deal to fix that on my end... just noting.
C4D 2025.1.1 v1.8.2 // Octane SA 2026.2, <<2 X 3090 + NVlink>>, Windows 11 Pro, X399, AMD TR 2950X, 128 GB RAM, NVIDIA SD 560.94
Octane User since V1 Beta
Return to “Releases”
