Does anyone know how I can uste Phoenix FXOceanTex ?
User avatar (Default)
merid888
Hello, good evening, I would like to know if someone know how I can use Phoenix FXOcean Tex ?
I mean appear if i select the option Get material but in the option of Octane i can't see this map to create Ocean water, in Corona renderer is more easy create Ocean water whit the Phoenix FXOcean text.
Thank you if someone could help me.
coilbook
merid888 wrote:Hello, good evening, I would like to know if someone know how I can use Phoenix FXOcean Tex ?
I attached the scene May be it will help. Make sure pure ocean is off if you need to simulate and render boat moving through waves. Also enable displacement map is so phoenix foam will stick on the surface of a displaced ocean.
ocean.zip
(54.42 KiB) Downloaded 88 times
coilbook
Hi Otoy,
Can you look at ocean subdivision in phoenix rendering tab. It used to make more detailed ocean and now it doesn't work. Thanks
merid888
Good evening, thank you for response my message
I'll text right now and I'll comment soon
Return to “Autodesk 3Ds Max”
