Cinema4D version 2021.1.7 (Old stable) 16.12.2022
maciek3d wrote:I have a fairly large 3d scene kitbash3d Minerva kit https://kitbash3d.com/pages/minerva
When I try to copy an object I get an error;
Started logging on 24.10.22 18:25:55
OctaneRender Enterprise 2021.1.6 (11000600)
OCIO error: Error could not read 'H:\3d enviroment competetion 2022\OpenColorIO-Configs-master.zip' OCIO profile.
VRAM used/free/max:0Kb/23.999Gb/23.999Gb Out-of-core used:0Kb RAM used:16.432Gb total:127.893Gb OpenGL free/total:0/0
Scene created in plugin version 10021601
Scene plugin version is older than version:2021.1.6-(R5)
Plugin will convert the parameters of displacement texture.
Animated attributes should be changed by manually!
FumeFx library initialisation error!
Export materials time= 32970.384 ms
Collect objects time= 20.382 ms
Mesh creation time = 6573.422 ms.
Api update time: 0.443 ms.
VRAM used/free/max:8.223Gb/12.337Gb/23.999Gb Out-of-core used:0Kb RAM used:45.7Gb total:127.893Gb OpenGL free/total:0/0
CUDA error 700 on device 0: an illegal memory access was encountered
-> failed to wait for event
device 0: direct light kernel failed
MB:0/0 ST/MOV:0/823 Nodes:1719 Tris:47.109m DispTris:0 Hairs:0 Meshes:823
Textures Grey8/16:0/0 Rgb32/64:272/6
you have two errors:
1. The ocio.config is loaded from a .zip file, please uncompress and assign the correct path.
2. CUDA error 700 is Nvidia driver related.
Please, perform a clean installation of 516.94 Nvidia Studio driver:
https://www.nvidia.com/download/driverR ... 969/en-us/
To perform a clean installation, please follow these steps:
After reboot, try with to do the same steps and report back, thanks.
ciao,
Beppe
ProTharan
Hi Beppe,
Is this version available for Macbook Pro M1's yet? I'm currently running PR14 on Cinema R25 on Monterey as that is the latest one, I am hesitant to install OS Ventura & C4D 2023, do you know if will PR14 work with this? Thank you!
maciek3d
ciao,
Beppe
Thanks Beppe, I did as you wrote and I still have the same errors :(
Started logging on 25.10.22 16:16:10
OCIO config file:I:\CASTLE\KB3D CHALENGE\OpenColorIO-Config-ACES-1.2\OpenColorIO-Config-ACES-1.2\aces_1.2\config.ocio loaded.
VRAM used/free/max:0Kb/23.999Gb/23.999Gb Out-of-core used:0Kb RAM used:16.197Gb total:127.893Gb OpenGL free/total:0/0
Export materials time= 37313.276 ms
Collect objects time= 21.664 ms
Mesh creation time = 6519.356 ms.
Api update time: 0.542 ms.
VRAM used/free/max:8.239Gb/12.21Gb/23.999Gb Out-of-core used:0Kb RAM used:44.446Gb total:127.893Gb OpenGL free/total:0/0
Export materials time= 72.366 ms
Collect objects time= 17.152 ms
Mesh creation time = 5008.241 ms.
Api update time: 0.538 ms.
VRAM used/free/max:8.225Gb/12.264Gb/23.999Gb Out-of-core used:0Kb RAM used:39.553Gb total:127.893Gb OpenGL free/total:0/0
MB:0/0 ST/MOV:0/823 Nodes:1720 Tris:47.109m DispTris:0 Hairs:0 Meshes:823
@ProTharan:
with M1/M2 mac, you need native OctaneX 2022.1-XB3-R4, please have a look at here:
viewtopic.php?f=9&t=80641#p416975
Ventura is not supported yes, so please stay with Monterey for now.
@maciek3d:
please write to help at otoy dot com, asking for Beppe, thanks.
ciao,
Beppe
There is a R6 build with some fixes. Enjoy it!
SSmolak
Such new things like Pyro (fire, smoke, explosions) will not work with Octane right ?
SSmolak wrote:Such new things like Pyro (fire, smoke, explosions) will not work with Octane right ?
What's that? I know but just asking for being sure
SSmolak
https://www.maxon.net/en/cinema-4d/features/pyro
https://youtu.be/7ESaB5WDlME
https://youtu.be/IE9Vdc1gKzc?t=137
It requires some converter functions to work with that. I haven't yet got some time but it's on table.
SSmolak
aoktar wrote: It requires some converter functions to work with that. I haven't yet got some time but it's on table.
Great. Just asking. I know that there are more important things to do :)
Disable OSL node cause that all tree is disabled too :
Return to “Releases”
