Just got with the program but dont understand how to do volumetric fog and god ray stuff, where do I start, should I use niagara ?
Thanks.
Volumetrics and god rays ?
Moderator: ChrisHekman
Ok I found a reasonable tutorial, this guy talks about octanerendertargetactor (details) sub selection 'environment' and a parameter called medium.
https://www.youtube.com/watch?v=vRq5hvaD72g&t=9s
I assume this is where I need to be, are there other methods ?
After 3 days of searching online for answers of how to do volumatrics in Unreal/Octane I have found squat.
Since there is no support i'm switching to Octane with Blender.
Later.
Later.
- ChrisHekman
Yes the environment node in the renderatarget actor can have a medium node that does fog.timulo2 wrote:Ok I found a reasonable tutorial, this guy talks about octanerendertargetactor (details) sub selection 'environment' and a parameter called medium.
Im sure there are other octane videos on youtube - for other octane plugins - that explain how to use the medium node.
Usually there are youtube vidoes that explain how to do it in the C4D plugin - it should work the same or similar in UE.
There are other methods aswel, you can create VDBs and import them as orbx files.
Or create an Octane Material with a medium that does fog and place it on an object in the scene.
