How do I stop texture layers from repeating?
leave2
Let's say I have a cylindrical object and I want to place a label on it. I take a layer material, create my material, and then create my second layer and then use an alpha to apply the image/text, right? I then set the border mode, and that stops the texture from tiling/repeating..
Problem for me is that the texture seems to appear on all sides of the image plane. So if I have a hollow bottle, it'll apply the texture four times, etc.. Screenshot included:
https://imgur.com/a/jNDodbt
I only won't this to appear once on the front, but it also appears on the back of the bottle, too.. Any idea what I could be doing wrong?
you can use the Triplanar node, with the logo (with Triplanar projection) on one axis and a black color in all the other axis pins:
ciao,
Beppe
boxfx
Or, select the polygons where the texture should appear, then under the c4d select menu run the "Store selection" command ("set selection" in older c4d versions). You should notice a small triangle tag appear next to your object in the object manager. Select the material tag on your model, the drag the triangle tag into the "selection" parameter.
leave2
Thank you so much guys, really appreciate the screenshots too, very helpful. Problem solved! Have a great weekend.
