Cinema4D version 2021.1.7 (Old stable) 16.12.2022
marshalartist
Latest version seems to be crashing on an empty scene just by adding a light object. Bug report attached
_BugReport.txt
(1.26 MiB) Downloaded 150 times
SSmolak
I have some technical question - we have the same shortcut "D" for Node Solo and Hold Updates in LV. Also using C4D material attribute manager Octane shortcuts doesn't work here. I think that this is little misleading. I don't know that this is possible but is there way to take control over C4D keyboard shortcuts to make Octane Solo "D" works in every C4D or Attribut Manager window ?
marshalartist wrote:Latest version seems to be crashing on an empty scene just by adding a light object. Bug report attached
In C4D 2023?
miohn
Hi Ahmet,
thanks very much for fixing this texture issue so quick!
R3 working fine now!
regards
Mike
vitusfilms
Hi Aoktar.
The dirt node seems to make Octane and C4D crash too (in C4D 2023)
marshalartist
Yes in C4D 2023
marshalartist wrote:Yes in C4D 2023
I'll test it and rebuild if I can fix the issue
rjohn
same here: C4D 2023 - newest Octane version: crashing on an empty scene just by adding a light object (e.g. add a target area light and click on the target-tag - crash)
moebius
in R2023, Octane(R3), I open an old procect (R26.1)
An Errormassage apears:
Missing Plugin: "Object Material" (ID 1035291)
Is this Octane related?
rjohn wrote:same here: C4D 2023 - newest Octane version: crashing on an empty scene just by adding a light object (e.g. add a target area light and click on the target-tag - crash)
I know, I'm on it
moebius wrote:in R2023, Octane(R3), I open an old procect (R26.1)
No
Return to “Releases”
