Camera jerking In Stand-Alone
Hey, paul
I'm putting this here because I think it's part of the same issue.
After further testing, I found out that the Dolly cam is a bit zoomed out in the standalone., when I export the animation.
The main camera it's fine. Is this a poser bug that will not be resolved anytime soon? Just asking because I use the dolly cam to animate a lot. I find it more user-friendly than the main camera.
The Bottom is poser and the top is Octane.
Can you send me this scene please?
spartan00j
face_off wrote:Can you send me this scene please?
Here's the file. Also Paul, I just realized that you gave me the 2022 plug-in version to resolve the jerking issues. The Standalone I have is a 2021.1.5. Could that cause the issue? I can't find a 2022 version of the Standalone on the forms.
dolly cam.zip
(182.1 KiB) Downloaded 137 times
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
Octane Standalone 2022.1 XB3 is available from viewtopic.php?f=33&t=80156.
I loaded your scene and it rendered correctly for me.
Keep in mind that the camera is matched HORIZONTALLY - so the horizontal extents of the Poser viewport should be matched in the Octane Viewport. Is it possible on the Octane Viewport you had zoomed a little?
spartan00j
face_off wrote:Octane Standalone 2022.1 XB3 is available from viewtopic.php?f=33&t=80156.
Sorry Paul you misunderstood.
The viewport is fine and poser it's when I export the animation to open an octane Standalone software that the camera zoomed out a little with the dolly camera.
Win 11
128GB RAM
RTX 3060 TI
I think I found the issue. Does this version resolve your problem please?
https://render.otoy.com/customerdownloa ... RPRISE.exe
spartan00j
face_off wrote:I think I found the issue. Does this version resolve your problem please?
Hey, paul
it's not exact but it's close enough. They're just a slight Zoom not Extreme as in the earlier cases.
I tested it with both cameras the dolly and the main camera. The main camera matches it perfectly as expected.
The dolly just has a slight Zoom but as I said earlier it's acceptable. I attached the image test.
Win 11
128GB RAM
RTX 3060 TI
Thanks for testing. That error would have been there for a few years! Also - you can tick Camera Motion Blur in the Animation tab, and then open the Viewport, and the Octane Camera will exactly match it's zoom that you will see in Octane Standalone.
spartan00j
face_off wrote:Thanks for testing. That error would have been there for a few years! Also - you can tick Camera Motion Blur in the Animation tab, and then open the Viewport, and the Octane Camera will exactly match it's zoom that you will see in Octane Standalone.
Okay Thanks
Win 11
128GB RAM
RTX 3060 TI
Return to “Poser”
