Cinema4D version 2021.1.7 (Old stable) 16.12.2022
MyDearestHao
aoktar wrote:
MyDearestHao wrote:Hello, when will it be repaired, the texture recovery function, and now the textures recovered in the 2021 version are still lost. The feature is fine on the 2020 version.
Hello,
What's that?
The new version reconnects to find the directory, and the textures are still lost. For this, I have to connect the textures on the 2020 version and go back to 2021. This function is used frequently for frequent handover of files.
Delizade
LV comparison line is now so better than before.
Thank you so much for this.
MyDearestHao wrote:
Hello,
What's that?
There is complicated cases to handle filenames. It's for providing more performance. But my revisions could cause some handicaps like that. It is like trying to close the holes by one hand. Please record a video to show the details and send me with a message via forum's DM.
MyDearestHao wrote:
Hello,
What's that?
I'm trying it and it's working on me. Could you please share example project and info about where's the linked paths?
MyDearestHao
Hello,
What's that?[/quote]
The new version reconnects to find the directory, and the textures are still lost. For this, I have to connect the textures on the 2020 version and go back to 2021. This function is used frequently for frequent handover of files.[/quote]
I'm trying it and it's working on me. Could you please share example project and info about where's the linked paths?[/quote]
I've checked for possible issues with Chinese paths, but it doesn't seem to be the cause.
tex.mp4
(19.17 MiB) Downloaded 2388 times
thanulee
Heya,
- Regarding linking assets, I have no issues with textures, but I have with VDBs.
They do not relink. I have to manually go and re add them to octane vdb.
I always had issues with relinking vdbs so it's not new here. I was wondering if that is an easy fix.
- A small thing, LV says 2021.1.5(R4)
Cheers!
ps. I love the new line in comparison mode
What's that?
I've checked for possible issues with Chinese paths, but it doesn't seem to be the cause.[/quote]
What's happening if you do same on a new scene or simpler scenes? It's like working on me. I need to reproduce it.
thanulee wrote:Heya,
Cheers!
Is it working with C4D's VDB objects?
MyDearestHao
What's that?
What's happening if you do same on a new scene or simpler scenes? It's like working on me. I need to reproduce it.[/quote]
I tested it in a simple scene, and it can be retrieved again, but I copied a small model from that complex model library and couldn't retrieve it.
But I can recognize it after switching to 2020. I don't know how to explain it.
Hi MyDearestHao,
I sent you a PM for a test build. I made a small revision by removing a case, not sure it will corrupt or not another functionality for images.
Return to “Releases”
