Hey Paul,
I'm getting a weird rendering issue in the octane standalone when rendering and animation I exported out the plug-in.
There's a camera jerk every 10 frames. I exported out the animations several times from the plug-in and I keep getting this camera jerk every 10 frames. From different poser files.
I tried adjusting the camera settings to match the frame rates. Turning off motion blur.
Extending render time.
Turning off shutter speed.
Still have the same issue every 10 frames
Camera jerking In Stand-Alone
- spartan00j
- Contact:
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
- spartan00j
- Contact:
Where is the setting located?elsksa wrote:Hi,
Instead of camera related, could it be due to the sub-frame value requiring adjustements? It's usually the case. Worth double-checking.
In the Standalone or the plug-in.
And in which tab.
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
Can you delete all props/figures in the scene and add a cube, then confirm the issue still happens, and if it does, send me the pz3 file please.
- spartan00j
- Contact:
Yes It still happens. Here is the PZ3.face_off wrote:Can you delete all props/figures in the scene and add a cube, then confirm the issue still happens, and if it does, send me the pz3 file please.
I also added the Exported animation from the plug In.
- Box.zip
- (33.81 KiB) Downloaded 217 times
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
I see the issue - it looks like a problem getting accurate Dolly Camera coordinates and angles. Using the Main Camera seems to be OK. I will report back when I know more.
- spartan00j
- Contact:
Paul I just tested it. The main camera Jerks as well. Not as bad but it jerks.face_off wrote:Thanks
Every 10 frames
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
- spartan00j
- Contact:
Also, I just realized I'm using version Poser 12.0.752 - 2021-11-24.spartan00j wrote:Paul I just tested it. The main camera Jerks as well. Not as bad but it jerks.face_off wrote:Thanks
Every 10 frames
Would that have anything to do with the issue?
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
Hi
This is caused by a bug in Poser 12 (including the latest version released a few days ago). I have been able to get around part of the issue, which may resolve your problem. Can you please try https://render.otoy.com/customerdownloa ... RPRISE.exe? This is the ENTERPRISE build using the latest Octane 2022.1 render engine (although does not include all the new 2022.1 nodes).
- spartan00j
- Contact:
Just tested it and it worked.face_off wrote:Hi
Thanks Paul
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
- spartan00j
- Contact:
Hey, paulspartan00j wrote:Just tested it and it worked.face_off wrote:Hi
Thanks Paul
I'm putting this here because I think it's part of the same issue.
After further testing, I found out that the Dolly cam is a bit zoomed out in the standalone., when I export the animation.
The main camera it's fine. Is this a poser bug that will not be resolved anytime soon? Just asking because I use the dolly cam to animate a lot. I find it more user-friendly than the main camera.
The Bottom is poser and the top is Octane.
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
