Cinema4D version 2022.1-XB2-(R2) (Experimental) 23.07.2022
Forums: Cinema4D version 2022.1-XB2-(R2) (Experimental) 23.07.2022
Moderator: aoktar
Re: Cinema4D version 2022.1-XB2-(R2) (Experimental) 23.07.2022
Postby aoktar » Fri Jul 22, 2022 10:25 pm
aoktar Fri Jul 22, 2022 10:25 pm
Hi all!
Please check new release. It fixes two problems which are reported.
Postby 841131100 » Sat Jul 23, 2022 6:11 am
841131100 Sat Jul 23, 2022 6:11 am
Why does it show white when the ACES tone mapping is turned on?
Postby chrisfranklin6002 » Sat Jul 23, 2022 8:38 am
chrisfranklin6002 Sat Jul 23, 2022 8:38 am
I'm still confused as to why 2 versions of the Plugin are being worked on? Surely 2022 would automatically be better? Isn't that the whole point of having it?? It feel a bit lie going backwards going back to this or does this have more features than the 2022 version I'm using, seeing as it's half way through 2022??!!
chrisfranklin6002
Postby chrisfranklin6002 » Sat Jul 23, 2022 8:39 am
chrisfranklin6002 Sat Jul 23, 2022 8:39 am
chrisfranklin6002 wrote:I'm still confused as to why 2 versions of the Plugin are being worked on? Surely 2022 would automatically be better? Isn't that the whole point of having it?? It feel a bit lie going backwards going back to this or does this have more features than the 2022 version I'm using, seeing as it's half way through 2022??!!
I read that wrong totally ignore me!!!!
chrisfranklin6002
Postby eyeonestudio » Sat Jul 23, 2022 12:03 pm
eyeonestudio Sat Jul 23, 2022 12:03 pm
aoktar wrote:Hi all!
Thank You. You are the Best. :o
CINEMA 4D R2023
Win10 / 10GbE / AMD3995X*2ea, AMD3990X*2ea, 10980XE*2ea / 256Gb RAM / RTX3090*14ea
eyeonestudio
Postby Kalua » Sat Jul 23, 2022 7:49 pm
Kalua Sat Jul 23, 2022 7:49 pm
Nice release, Aoktar! Thank you as always!
Could you complete de Rayswitch node interface?
Regards,
C4D 25.117 Octane 2023.1.2 R4, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 552.22
Kalua
Postby SSmolak » Sun Jul 24, 2022 12:08 pm
SSmolak Sun Jul 24, 2022 12:08 pm
If render settings buffer type is set to HDR Float 16-bit or LDR and color space is set to sRGB it freeze during rendering to PictureViever.
RTX doesn't work.
SSmolak
Postby eyeonestudio » Mon Jul 25, 2022 5:41 pm
eyeonestudio Mon Jul 25, 2022 5:41 pm
ACEs Tone Mapping
LV - HDRI Environment - Visible Editor, Renderer Off - It turns white.
LV - HDRI Environment - Clipping Dark Area
CINEMA 4D R2023
eyeonestudio
Postby eyeonestudio » Fri Jul 29, 2022 8:25 pm
eyeonestudio Fri Jul 29, 2022 8:25 pm
Report : Octane Volume Object(VDB Loaded) + Standard Volume
CINEMA 4D R2023
eyeonestudio
Postby aoktar » Sat Jul 30, 2022 12:19 pm
aoktar Sat Jul 30, 2022 12:19 pm
eyeonestudio wrote:ACEs Tone Mapping
Please put some example scenes.
PreviousNext
Return to Releases
Users browsing this forum: No registered users and 9 guests
Sun Jun 16, 2024 12:50 am [ UTC ]
