Octane Texture Manager
Ilius
Are there any plans to make it better?
Its a good tool for finding textures that may be too big and arent plugged inside an imagetexture-node properly or dont have the correct gamma and so on.
But the little things are what make it so annoying whatsoever.
It doesnt update after a texture is switched out for another. (ok there is an update button for that and it could maybe be annyoing if it did itself all the time)
you cant sort the list by anything. i would like to be able to sort it by Size for example.
It would be nice to be able to add or remove critera for sorting, for example i dont need to see suggested and real path, take up to much space.
But if i could see Legacy gamma and color space at a glance, that would really be helpful.
maybe even a checker mark telling me if its propberly inside a textureimagenode.
Hope nobody takes it personal, its just some thoughts and suggestions.
Hi there,
Thanks for thoughts. We'll consider to improve it more. For update button, it was a must because auto refresh was causing big lags. I'll bring back it if I can find a better system with less lags.
boxfx
If we're taking texture manager requests, there's 1 thing which would bring a tear to my eye. The ability to find and fix texture paths in the project.
ie. a button or menu command called "find missing textures". You click it, and c4d asks you to select a folder/drive. Octane would then search the child folders for any missing texture files. Finally asking the user if they want to link directly to the file, or if they want to copy them to the local tex folder.
This would save me so much time when copying and pasting objects from one file to another.
SSmolak
boxfx wrote:If we're taking texture manager requests, there's 1 thing which would bring a tear to my eye. The ability to find and fix texture paths in the project.
You can do the same using standard C4D Project Asset Inspector.
Are you talking about this features? Assuming we have what you want. Isn't?
SSmolak
aoktar wrote:Are you talking about this features? Assuming we have what you want. Isn't?
Yes you can do the same even with simplified way because Asset Inspector finds missing textures automatically.
Missing textures are marked as red in our manager also. I don't get why do expect more
SSmolak
Sorry my answer was to boxfx. For me both texture manager and asset inspector works fine but Octane texture manager can be very slowly using many of textures and setting compression for multiselected textures doesn't work as expected.
SSmolak wrote:Sorry my answer was to boxfx. For me both texture manager and asset inspector works fine but Octane texture manager can be very slowly using many of textures and setting compression for multiselected textures doesn't work as expected.
Yes changing the compression has glitches and it's not allowing to apply different compressions to same filenames.
