Motion Blur not properly evaluated with expression/constrain
Forums: Motion Blur not properly evaluated with expression/constrain
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby blobbybarack » Fri May 06, 2022 5:35 pm
blobbybarack Fri May 06, 2022 5:35 pm
Object Motion is not properly evaluated if property is not keyframed (expression/constrain/Chops network,etc).
Have to double check but i'm pretty sure it should be the same issue with camera motion blur if your camera is animated with something else than traditional keyframe.
Anything to deal with this issue right now other than baking ?
Kinda problematic in a procedural workflow.
blobbybarack
Re: Motion Blur not properly evaluated with expression/constrain
Postby juanjgon » Fri May 06, 2022 5:39 pm
juanjgon Fri May 06, 2022 5:39 pm
Can you share an example scene, as simple as possible, with this issue?
juanjgon
Postby blobbybarack » Fri May 06, 2022 6:41 pm
blobbybarack Fri May 06, 2022 6:41 pm
Sure my bad.
Check both Rop.
Second geometry is the same than the first one but baked (the visually correct one).
https://www.dropbox.com/s/p4uht2zoel2p49b/MBIssue.hip?dl=1
blobbybarack
Postby juanjgon » Wed Jun 22, 2022 10:11 pm
juanjgon Wed Jun 22, 2022 10:11 pm
Sorry, I was checking this issue in Octane 2021.1.5.0 but it seems that I can't reproduce it. Do you still have this problem using this latest Octane 2021.1 version?
2022-06-23 00_10_37-C__Users_juanj_Downloads_MBIssue.hip - Houdini FX 19.0.622 - Python 3.jpg
juanjgon
Return to Bug Reports
Fri Jun 07, 2024 1:08 am [ UTC ]
