Cinema4D version 2021.1.4-(R4) (Stable 2021) 21.04.2022
SSmolak
After changing LV camera behavior Octane stopped updating materials - if new polygons are included or excluded from material tag or new material is added to objects. There is need LV restart to update them.
SSmolak wrote:After changing LV camera behavior Octane stopped updating materials - if new polygons are included or excluded from material tag or new material is added to objects. There is need LV restart to update them.
Changes are not related to other parts. Make sure you are checking well. Otherwise share your examples.
SSmolak
Checking are ok. Changing material properties works fine but adding materials updates
new after 15-30 seconds. Never had this before in previous versions. Even updatinggeometry changes is slugish. This is scene with a lot of generators. I will test more
SSmolak wrote:Checking are ok. Changing material properties works fine but adding materials updates
Camera navigation update and this is not related. It should be scene specific, even maybe driver or viewport related.
hazenkind
- xpGroup object support
Awesome! THX!
Kalua
I have noticed Camera movement has started to not update in LV window in some cases: when I am using "Takes", and I copy the set camera and keep using the Take set camera, I need to change the set camera and back to make it responsive in the Liveview window.
I may make a video if it sounds too confusing to understand.
Otherwise R4 is working great!
Regards,
Octane User since V1 Beta
Regards,
Yes please! I'm not seeing issues on my usages, maybe because I'm not using takes. Btw these are not related with latest update, maybe was here and you notified now.
You may try with older versions and report back
wangdanyang1120
I met a problem.
After version 2021.1.1-R3.Surface Type of Octane Scatter,can't scale with object.
scene.zip
(51.76 KiB) Downloaded 167 times
Kalua
Regards,
True! I think it started on 2021.1.4 R3 or even before. Will post .gif shortly.
Return to “Releases”
