Display Color to Octane Material?
Meshmashuk
Hi there,
I'm wondering if there's a way to get Octane materials to use an object layer's Display Color (in the Basic Tab) to output multiple colors for different objects from just one material? With C4D you can use the MoGraph Color Shader because, without a cloner or other mograph generator, it respects the Display Color of each object and will render that.
I have an AI file with many many layers that have succesfully imported using CV-ArtSmart, assigning the AI fill colors to each object layer's Display Color. They display perfectly using a C4D Shader with a MoGraph Color Shader applied to the Color channel. But if I create the same setup using Octane - Creating an MGColor Node and attaching it to the diffuse channel - it doesn't work. It only works when Mograph Generators are used.
Hope that makes sense!
If you can transfer color to mograph color shader, the plugin will recognize that.
Meshmashuk
aoktar wrote:If you can transfer color to mograph color shader, the plugin will recognize that.
I thought C4D kind of worked the other way round. MoGraph effectively alters the display color which is what an MGColor shader looks at to get its color information. This is why a C4D MoGraph shader will work with either a MoGraph generator based color or the simple Display Color, set in the Basic Tab - because, in the end, it's always reading the Display Color.
I don't know how to make MoGraph read the Display Color as wouldn't this cause a kind of recursive loop?! I have tried but I can't see a way to do it. If someone knows how to use Fields or something to get that Display Color across into Mograph and not cause the universe to reformat I'd be delighted to know!
Ignaco
I actively come back to Redshift for projects, because I can't use Display color in Octane which is kind of sad.
Ignaco wrote:I actively come back to Redshift for projects, because I can't use Display color in Octane which is kind of sad.
On latest builds you can use Display color by using octane tag
jalejune
@aoktar Could you explain the steps how?
Gregor.Zimmermann
It would be amazing to know, how to use this feature, @aoktar
Thanks a bunch!
You need to use displaycolor OSL and object tag as in this scene. Check it out!
display-color.zip
(111.71 KiB) Downloaded 401 times
pxlntwrk
Thx , nice tip :D
pxlntwrk.net
tobefree
Awesome this feature is included now,
I just realized, that there is a color shift betweenn having a color defined in the octane object tag and using the osl node (or using the custom object color) and using an RGB spectrum with the exact same color. Any idea how to fix that?
Cheers,
Tobi
