How to export ORBX?
Houdini Integrated Plugin
HMXMedia
juanjgon wrote:Hi,
The next Octane 2020.0 plugin build will add the support of mesh and hair objects with a non-constant topology while rendering or exporting sequences in update mode. This should help while exporting these kinds of scenes that only could be rendered in full scene reload mode before.
Wow I've just tried it , that's great!
Thank you
Fake Pilot
How? Where? What? Please tell me how, I'm still stuck with trying to get my animation to work with ORBX export..
Machine: Macbook Pro M4 Max, 128GB.
lamloops
Hi gang
Apologies for digging up an old thread, but like the OP from five years ago I can't seem to get the orbx file to appear. I've tried with and without an extension and I'm using a file path in the 'Base file name' box in the Archive tab. I've set the rendering mode to Update Scene, and it was on by default and not working. I tried switching to Full Reload and render and then switching back, but that didn't work either. Is there something that I'm doing wrong, or another parameter that I need to change? I can see the alembic is being created in a folder but no orbx.
Warm Regards
juanjgon
lamloops wrote:Hi gang
Warm Regards
Can you please share your scene to take a look at it here? In update scene mode the .orbx file should be created, but perhaps there is something not supported in your scene.
lamloops
Hi Juanjo!
I hope dropbox links are okay; the hiplc file extension isnt allowed. Link
thanulee
Jumping in this thread. ORBX is so freaking amazing I just imported millions of particles in c4d with Cd/pscale, so so happy!
One thing, it exported every time (while couldn't replace an existing file) but kept popping this error.
I'm new in H so I might have done something wrong in my setup so here is also a scene:
https://www.dropbox.com/s/nh7i1cs46acux ... hiplc?dl=0
james_conkle
I tried Thanulee's scene and after I cached the scene and removed the HDRI it exported the ORBX without error... until I tried to export an ORBX again with a new filename. Then I got the same error but the error referenced the name of the previous ORBX. This goes away when I quit Houdini and load the scene again.
Feels like it's expecting to render the ORBX with the same name if one was rendered during the same Houdini session.
I was able to successfully open these ORBX in standalone even if they had the error in Houdini.
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
lamloops
Hi Juanjo!
lamloops wrote:
Hi gang
Warm Regards
ORBX files are also not showing up for me in Cinema 4D. Pic of the error is attached.
Here's the C4D project. Link
Could it possibly have to do with moving Octane's AppData/Local/Roaming folder to a different location? Or maybe could it be a license issue? I just got an enterprise license, but my studio license hasn't expired yet.
standalone opening attempt.png (6.71 KiB) Viewed 3143 times
lamloops
lamloops wrote:
Hi Juanjo!
Found a solution for this strange problem.
1. make sure the folder you are exporting to is completely empty
2. if that doesn't work, create a new octane ROP fresh, with new settings
3. if those dont work, try setting Houdini's render frame range to start at 2
Return to “Houdini”
