Cinema4D version 2021.1.4-(R4) (Stable 2021) 21.04.2022
SSmolak
Ron, I had delays in scenes with some amount of textures. Disable this and it should gone.
Also how to do OGL Octane material preview for 64kb always not default ? Where is setting for this "default" ?
Ron
SSmolak wrote:Ron, I had delays in scenes with some amount of textures. Disable this and it should gone.
Thank you for this hiint - but unfortunately it is laggy even in scenes with just one cube and no textures at all.
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
Close C4D, delete "oct.dat" from R25's prefs directory. And start again the C4D. This will make all settings gone to defaults.
Ron
Thanks, Ahmet! That did it!
New build is available to fix a few issues. See first page. Enjoy it!
Kalua
aoktar wrote:New build is available to fix a few issues. See first page. Enjoy it!
Thanks! Working great!
Octane User since V1 Beta
Weirdpictures
Hi Ahmet,
thanks once again for this quick update of the plugin - so far it works great, no issues. We do however run into a small issue that i feel has been addressed before and I think was not yet working with Octane in general.
We are animating a quick camera zoom, basically changing the focal length of the camera, as if you would do with a zoom lens in real life. But we cant get any motion blur, since the camera is not moving, but just the focal length. In real life this quick speed zooms will make quite a big motion blur, so not sure if there is a trick to enable something similar within C4d with octane.
Anyone have any idea how to maybe cheat this :-)
Thanks for all the great work Ahmet, couldn't live without your plugin anymore :-)
SSmolak
Zooming in-out is terrible slow now in LV. Can't work with this. Moving much slower too than before. This behavior should be as option if this cannot be repaired.
SSmolak wrote:Zooming in-out is terrible slow now in LV. Can't work with this. Moving much slower too than before. This behavior should be as option if this cannot be repaired.
What are you talking about? Which zooming?
SSmolak
Generally moving camera in LV is much slower now, especially zoom in/out - moving forward -> alt + right mouse button. Also it randomly rotate view in different direction.
Return to “Releases”
